Kapanadze Cousin - DALLY FREE ENERGY
Started by 27Bubba, September 18, 2012, 02:17:22 PM
0 Members and 2088 Guests are viewing this topic.
NickZ
  AG and Hoppy:
  In case you haven't seen this video, below. Check it out.
  The missing link to the mystery of these self runners.
  The banana...
   Akula and Ruslan Free Energy generator demonstration 4kW - YouTube
   Except that he's wrong.
   Thanks to Wesley's visit.
AlienGrey
I don't see how it can, this is the way the real ones work note how he does every thing, and how he sets
things up and the way the coil's are arranged, Hpppy is aware of how it should realty work the evidence
is in the data base he knows it needs a radiant oscillator on the front end  he saw the circuit !
https://www.youtube.com/watch?v=7SBcezHASts
https://www.youtube.com/watch?v=A1GoXhTUaeA
magpwr
Hi Geofusion,
May i ask have you taken note of the frequency in khz of pwm and tesla coil,pwm duty cycle where i last mentioned about seeing red\orange spark at Antenna.
Because i am more curious on the frequency output and it's harmonics relationship to obtain a visual comparsion on the both waveform at my end.
If you can't get measurement at all due to lack of equipment.Then it's ok.I won't step in anymore.
NickZ
Quote from: plaxius on November 23, 2017, 04:53:29 PM
what is the frequency relationship between kacher and pushpull ?
Is the frequency of the kacher really important? I have seen different configurations with flybacks and other high voltage transformers but it seems to be more important the synchronization with the push pull.
   We don't really know if the exact running frequency of the Kacher is all that important, or not. But, it's better to build the system the way that it's designed.
   Every self runner shown up to now have been running at a totally different frequencies.
   My kacher operates between 850KHz to 1.1MHz. Which can be controlled by movement of the ferrite in the Kacher, as well as by adding or removing wire turns on the secondary coil of the Kacher.
   While my induction circuit is running between 13KHz to 27KHz. This will vary according to the load.
   Adding more bulbs, lowers the running frequency, and the TL494 needs to be readjusted for the new load.
   So, where the best sync happens depends in part by the load that is being used, as the load becomes part of the circuit, as well as the ground line.
   If adding the ground line produces no additional output at the bulbs, that is one indication that the system is not tuned right.
Hoppy
Quote from: NickZ on November 25, 2017, 09:50:14 AM
Nick,
Are you able to demonstrate the earth connection increasing the output at the bulbs?
