Kapanadze Cousin - DALLY FREE ENERGY
Started by 27Bubba, September 18, 2012, 02:17:22 PM
0 Members and 1341 Guests are viewing this topic.
DavidWolff
Well I'm not too convinced by any of it. none of it adds up to what Sergey, Enjoykin and Adrian were showing or saying
I get the idea a good part of the tread it's all about muddying the waters, even the grenade isn't wound correctly to get zero inductance.
So what's your track on the inductive winding what do you think that does ? Come on lets hear the jokes
And then there is the katcher what do you suppose is the truth about that ?
Come on lets rip this original idea of some ones fag packet apart and let see if we can get somewhere.
Thing is if you think the device works as is then there is no hope.
Dave
GeoFusion
Quote from: NickZ on April 18, 2020, 05:01:09 PM
   Geo. So,  can you show us wbat you can do now, with your device?
Hi Nick,
Soon, I'm making the bench setup in a much simple way now so when to add and remove is easier and
then to set it back how it was but without instability.
Take a look.
This is one of my recordings 4 years ago
https://www.youtube.com/watch?v=IdMVSiX2V7k
This clearly shows me now that I had something back then and I didn't even realize it up till now...
input is not affected when loading 300W low lumins or not loading anthing , input amps stay the same.
The Back Emf is what is filling up the cap, secret is not the diagram nor special frequencies,
I didn't even wrry on modulation...
Ofcourse for better performance you tune the telsa to the grenade but mines was not 100% tuned to it yet it gave result.
This is all about how you tune the coils and pulses of the tesla coil and when to interrupt when a field is in a certain moment.
Although 4years back it was by luck most of the time also having it right in the spot but not 100%.
***I'll make some sense in this for a moment how i view this device inner workings.
     We need to think and see we are standing near a Pool of water and you are standing at one of the sides of it.
     Now you trow a small rock in front of you in the pool which then creates ripple waves that travel..
     that will travel till the very other side of the pool
     and will reflect against the very end of the other side of the pool and come back
     and on the way the waves are growing larger when it reaches back to your side....
     That coming back ripple is the example just  B.E.M.F. ( a response ) and What if you could accelerate it?
     Imagine now in the when the ripples are coming back and your friend that is on the otherside is trowing a rock but fast
     right behind the ripples/waves and creates a nasty bigger waves that will come back, This is where you induce pulse.
     That is the work of the Tesla coil brief Pulses on the correct moment when tuned.
     So now to bring it on the device, When the Field is generated by pushpull via yoke over the 3T coil serie resonance
     when Current is Highest is where voltage is low then the pulse of Tesla Should be fired to give the amplification effect
     and having the cap at the grenade end to harvest it and in resonance at the same time. it's right when a field collapses.
This is what I see and what I have experienced and what I lacked of explanation of the guyz that have it.
Quote from: Utopia Now on April 19, 2020, 03:47:14 AM
Hi GeoFusion
Nice to hear from you   ... I am enthousiast  to learn more from you.
On what frequency does your Grenade resonate.
Are the first 2 layers wound one way and the second 4 layers the other way ?
Anyway cool video`s on your channel.
I heard you talk about the modulation coil   .. sounds like  you call that bifilar coil  or  do i misinterpret what you say i do`nt understand what you said there
Utopia Now     I am Happy :)
Hi Utopia,
No, I was not busy at all with modulation settings.. and I do not promote that.
Frequency of granade and tesla coils vary for everyone so if you use mines it wont make sense. have to use Scope.
What does make sense is to tune the system when you know you generate a field over the grenade
and when it collapses you have the HV pulse briefly at that moment to Spike up the Bemf that is coming back.
Quote from: DavidWolff on April 19, 2020, 08:56:10 AM
Dave
Hi Dave,
I know what you are saying, Some of these guys have schematics made or did also experiment on it, but maybe also
had no idea what is happening. this is why some of them only show what they think it is without good experimentation.
Some like Adrian Dniester had success with the device and figured it out. but also did not share because he is bought by
companies out there, same goes for Ruslan and others who have it or maybe had...
The kacher, the reason why it is there is to give a short pulse on the right moments of a collapsing field.
It could be any type of HV transformer at work as long as it does the very short pulses it has to do when it's time.
Hmmmmm....
It's all to know and see if it is possible but without proper test on the bench there will be no progress.
Do some Uncharted water experiments as how I did
and there we can see what is real and what not, many schematics I have
concluded as BS but not all and some of these schematics are not full given truth.
This Device works, It is just that ppl don't understand it yet.
Without HV Pulse the Device is Useless. it has to be a interrupted one.
ppl are not used to work with some of these energies in this way....
Void
Hi Geo. BEMF (Back EMF, AKA Counter EMF ) is not the same thing as Inductive kickback spikes.
I have explained that several times already in this thread over the years. I believe you are referring to
inductive kickback (AKA flyback spikes).
If someone really has something, they should be able to demonstrate it in an clear and reasonable manner.
All else is just talk.
All the best...
GeoFusion
Quote from: Void on April 19, 2020, 05:12:33 PM
All the best...
Hi Void,
Alright, hmmmm then it must be that then.
I was not 100% sure if it was BEMF directly but the inductive kickback sounds more tobe it if so.
But the point to all of this is for all to understand what is causing this device to function.
Soon enough I'll post a demo
Cheers.
Void
Quote from: GeoFusion on April 19, 2020, 05:35:18 PM
Hi Void,
Cheers.
Hi Geo. No worries. It's just that it can tend to confuse matters.
When a voltage (EMF) is applied to a coil, a current starts to flow in the coil.
The coil then generates a counter EMF (back EMF) to the applied voltage on the coil which opposes the applied voltage
(it is oriented 'counter' to the applied voltage, i.e., pushing 'back' against the applied voltage).
When the applied voltage to the coil is switched off suddenly, the magnetic field around the coil collapses and creates
an 'inductive kickback' (flyback) voltage on the coil which is aiding to the originally applied voltage (the kickback voltage is oriented
in the same direction as the applied voltage was, so it 'tries' to keep the current flowing in the coil in the same direction as it was originally flowing).
So Back EMF is counter to the applied voltage on a coil and occurs only when the applied voltage is still turned on, while a kickback spike is oriented in the
same direction that the applied voltage was oriented when it was connected to the coil, and occurs when the applied voltage to the coil is switched off.
