Kapanadze Cousin - DALLY FREE ENERGY
Started by 27Bubba, September 18, 2012, 02:17:22 PM
0 Members and 1090 Guests are viewing this topic.
verpies
Quote from: NickZ on April 21, 2020, 11:22:49 AM
   Lanca:   You have now posted on at least 10 threads on this forum.   I think that it is time that you leave. You are disrupting these threads, and I believe NOW, that it's being done on purpose.
Maybe he is an AI.
He has disrupted several of my threads, too ...at critical moments.  He was very good at it.
Raycathode
 who knows
Any way, the Akula advanced Katcher circuit gives out a very narrow pulse to drive the
output bipolar tranister, Tesla coil  STCC guys use the same idea to magify the Corona
discharge  to make it jump a bit like the Sars and Covid 19 leap.
conico
Hi Soliman,
I'm sorry Soliman but 1nf with a wire in pin 4 of TL494 doesn't work for me. When I start Katcher at 1.7Mhz I have this signal on the mosfet Gate and it is also on the mosfet cooling radiator as well.
My Katcher is very weak, less than 1000V on the antenna at 1.7Mhz. The only noise I have is this signal of 1.7Mhz. If I'll make an controllabile Katcher, the noise will disappear.
Soliman ,
how can I have a 10-90 degree phase shift between the Grenade coil signal and the inductor signal?
I think, this phase shift is the most important.
soliman
Quote from: conico on May 03, 2020, 07:57:40 AM
Hi Soliman,
Soliman ,
Hi conico,
some circuits use pin3 grounded, some don't use it at all. Both pin3 or pin4 can be sensitive, this depends on which circuit you have. is using. but if you Get the effect, no need to use the antenna.
An interesting variant of TL494 that I found on the internet is that  You can use the circuit as an AM modulator. The input would work like the antenna.
but you must modify it to work as a push pull. This circuit is also very sensitive.
I have noticed that the change of face can be modified by changing the capacitor of the 4 turns or by varying the duty cycle.
If the duty cycle is not adequate, the quality waveform of the grenade may be deformed, but at the best, a better waveform can be achieved by fine-tuning the duty cycle.
This is what I have been able to see in practice.
https://www.google.com/url?sa=i&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3D28oj7Ckkubs&psig=AOvVaw1DOaFpLluzAJeHdo1mF7I0&ust=1588598746709000&source=images&cd=vfe&ved=0CAIQjRxqFwoTCJDfk9Lll-kCFQAAAAAdAAAAABAD
NickZ
Quote from: Raycathode on May 03, 2020, 02:37:15 AM
Hi any chance you can ENLARGE the section your reference to wiring diagram is blurred (out of focus) cheers
   Ray: In order to be able to zoom in on Geo's linked diagram, you have to first download the App.
Then you can read the values, etz.
