CG Showcase of Overbalanced Wheel
Started by helloha, September 20, 2012, 09:55:52 PM
helloha
Analysing of Bessler's Clues 51.
< Improvised Method, Extraction of Water >
- if there is one resources on earth that is more important than energy, that would be water
- so, can use the output of the wheel, combined using the technology of atmospheric water generator (AWG) to extract water from air
- or, boil (or other methods, like desalination etc) seawater to extract drinkable water
helloha
Analysing of Bessler's Clues 52.
< Improvised Method, Vacuum Room, null Air Resistance >
"These few who saw the inside of the wheel after removing the front panel said that it had many compartments around the perimeter of the wheel, each with a shifting weight inside."
- if there are weights shifting within the wheel, and including the rotating motion of the wheel, it would be reasonable to vacuum out the air to reduce any air resistance, and so improve the workability of the wheel
- way of implementing the vacuum condition for the wheel
1. housing a number of wheels within a room/building, and vacuum out the whole room/building
2. place individual wheel within a container, and vacuum out the air inside the container
- extra info... moon has zero air resistance
helloha
Analysing of Bessler's Clues 53.
< Improvised Method, Gravity of Moon and Mar >
- gravity of
1. earth = 9.81 m/s2
2. moon = 1.622 m/s2
3. mar = 3.711 m/s2
- a speculation that if Bessler Wheel works based on gravity (used on the rolling weight) and
leverage (difference of torque force based on sum of rolling and swinging weights) and other
factors related (more or less) to gravity, then there's a possibility that the wheel can also apply on moon and mar
- relevent info refer to
1. "Act of Gravity, Motion of Weight"
http://www.overunity.com/12742/cg-showcase-of-overbalanced-wheel/msg407940/#msg407940
2. "The Right Angle and the Small Angle Swing"
http://www.overunity.com/12742/cg-showcase-of-overbalanced-wheel/msg408961/#msg408961
3. "Karl's Peg blocking vs Bessler's Child stepping"
http://www.overunity.com/12742/cg-showcase-of-overbalanced-wheel/msg408643/#msg408643
helloha
Analysing of Bessler's Clues 54.
< Improvised Method, Production of Hydrocarbon, Reduction of Carbon Dioxide >
- refer to image for simple concept to blend the wheel to the production of hydrocarbon
- there are technology in-the-process of research for the conversion of carbon dioxide to liquid fuel and other applications, search google or youtube for 'carbon dioxide conversion'  etc
helloha
a.3 Candidate for the Double-ended Club
- refer to image and video to spot the modification
