CG Showcase of Overbalanced Wheel
Started by helloha, September 20, 2012, 09:55:52 PM
helloha
b-IV. trying my hands on wm2d, magnet affecting the weight of object 05
- sim an Electrostatic Artificial Gravity environment
helloha
b-V. trying my hands on wm2d, magnet affecting the weight of object 06
- sim an Electrostatic Artificial Gravity environment vs Earth Gravity
helloha
b-VI. trying my hands on wm2d, magnet affecting the weight of object 07
helloha
Analysing of Bessler's Clues 65.
< Little Info, Wheel's Mass and its COM (center of mass) >
"By way of additional proof about its internal motive power, the perpetual motion machine was translocated to another support in such a way that the whole assembly could see over and under, and both sides of the machine; and all present were invited to visit the bearings, but no holes were found, all present examined them with their eyes, but no sign of fraud was there seen. It was possible to translocate the machine and turn it left and right as many times as was asked by the assembled respectable Commission."
"Before translocating the wheel, the Inventor who was performing the test for the officially appointed Commissioners, took out the weights and permitted one of them to be touched, wrapped in a handkerchief."
- the wheel with a diameter of 9-12 feet, in order to be able to translocate it to another support, it's best to build the wheel as light as possible, but still strong enough to support all the weights (swinging and rolling weights)
- also the mass of the wheel might affect the center of mass of the wheel, in turn affect the wheel's turning ability
- if the mass is too heavy, there's a possibility the wheel might not be able to start its initate rotation
- refer to image to see the difference in the center of mass between light and heavy mass of wheel
- this is based on assumption that the further distance apart the center of mass from the pivot point, the better for the initial/start turning of the wheel
helloha
Analysing of Bessler's Clues 66.
< Little Info, Distance between Weight and Rim >
- refer to image for description,
- based on info from the image, it is best for the weights (swinging and rolling) to be arranged near to the rim of the wheel
- related info, link to "Equilibrium"
http://www.overunity.com/12742/cg-showcase-of-overbalanced-wheel/msg416425/#msg416425
