Alum Epson salt car battery electrolyte conversion from sulfuric acid
Started by hartiberlin, October 07, 2012, 05:23:58 PM
hartiberlin
Hi All,
today I experimented with converting a normal old car battery with sulfuric acid
to Alum Epson salt  electrolyte.
I was not shure when I started this, if this old battery had all cells
without any short circuit, as it also only charged up to around 8 Volts before the conversion
on a normal battery charger....
But later I found out, that 2 cells were basically shorted out abd another cell
was particially shorted out....
But the basic conversion works fine....
Just have a look at my last 16 Videos I recorded today here;
http://www.youtube.com/user/overunitydotcom/videos?view=0
Enjoy !
Regards, Stefan.
hartiberlin
What I learned also from it, that you can easily measure the single cell voltage and if single cells are defective
by just poking your measurem,ents tips from a multimeter into the
cells touching the alum or also just tap water and see their cell voltage.
If the cell is damaged via a lead powder residue shorting out the cell at the bottom of the cell,
then the cell will only show less than 300 Millivolts.
If it is a good cell, then without a load and charged up it should read at least around 1.5 to 2 Volts...
Regards, Stefan.
P.S. When I am home again in a few days I will buy a fresh new lead battery without any acid in them and start over again
and will post the results.
