0 Members and 64 Guests are viewing this topic.
tturner
hey guys newbie here looking for some advice. im wanting to build a fe devise to power an electric bike or car. this means needs to be portable a small enough. any suggestions would be awesome.
forest
Exactly, what is the difference hanon ? I think it's easy to find. Just answer the most simple question : what is the basic difference between transformer and dynamo principle ? The answer is always in question. We saw it in equations...
I think most of us here know that part of answer now. I will not  tell what I mean because I learned that the only comprehention is when two people found own interpretations and then agree, every explanation lead to confusion, but here we have something very simple...
The only trouble is how Figuera was able to do so .... incredible indeed...because it looks like impossible task...
NoMoreSlave
Hi Cadman,
since my first post, i was waiting for such observation! you got ist my friend:)
Hola Hanon,
si hablo espaniol: https://archive.org/stream/dynamoitstheory02wallgoog#page/n154/mode/2up
THE SECRET IS THE TORIDAL ROTOR AS SEEN IN THE FIRST DYNAMOS MACHINES (remember the introductions in the patents, the first spot or the starting point of Figuera`s investigations).
as we dont want to rotate anything, there is no need to make it round, only if you want to re-use some existing stuffs...
Enjoy, comment & share!
NMS
NoMoreSlave
Oh yes!,
we have to adapt this code to do the multi-Phase sine wave (6 Phases needed to get 3 Phase figueras generator, 2 phases are also wellcome).
each 2 Phases must be set at 90º of Phases, in order to work together, so we get ONE Phase. then the next 2 phases schould also be set at 90º and theire output should be set at 120º from the first output phase, and the same with the other 2 phases (5&6).
In the modern Pure sine waves inverters, we have:
1: 12/24VDC to 300VDC booster (we need this to start the system)
2: H-Bridge feeded with the 300VDC (ore less) & gated by SPWM (in PIC uC we can use CCP  Modules)
3: LC Thank to smouth the 220VAC output
4: make transformer as in the drawings (wind extra coil for the looping: 100V & 1 A or 2A no more)
I may be wrong, but  we are to learn from each other...at least that s what i think....
Code it & share it with the world! dont be selfish! this planet need our urgent help...
Chemtrails are not a solution, killing peoples ist not the soluction, making money with others blood ist not a solution!!!...wake up humman race!!!!
NMS
