0 Members and 94 Guests are viewing this topic.
bajac
Thank you for providing the links to the patents.
I would like to say that you do not need to build any device in order for you to post in this thread. Very valuable contributions can be made by posting meaningful information. There is no need to send me a personal message. Just post it here.
I do not agree with threads that only persons building the devices are allowed to post, but I do respect their rights.
Thank you again for your contributions!
Bajac
madddann
Hello everyone, hello Hanon!
No need to thank me. I just wanted to say that I built that circuit shortly after posting it here and it worked fine (the waveform on my scope also looked fine). The problem I was having was very low power on the output coil (induced), but that might be my fault, 'cause I wound the N and S coils with too small diameter magnet wire, so the coils at 36 ohm came out only about 500 turns instead of atleast few thousands and did not fill the bobin even by 1/3.
The other thing I did, I used a fixed resistor instead of the rheostat. The resistor (rheostat) in this circuit wastes quite a bit of power, so to avoid that you can order a custom made transformer with adequate output voltage (need to determine the voltage by experimenting) and use it as the second transformer in the circuit, than you can eliminate the rheostat and with it the looses (heat from it).
I might rebuild this circuit and retest everything, but gotta find the right wire size for the N, S coils.
Hopefully others will test this circuit too and post their results, so we can compare and come to a conclusion about if this circuit behaves right for the Figueras 1908 patent replication or not.
For thoose who want to test this circuit, please look at this post, there is all the info you need to replicate it:
http://www.overunity.com/12794/re-inventing-the-wheel-part1-clemente_figuera-the-infinite-energy-machine/msg394315/#msg394315
If you have questions just ask here and I'll answer.
Happy testing everyone!
antijon
Hey Hanon, I watched the Gap power video. haha, I like that guy. I don't exactly understand what he's doing, but it's generating so I'm liking it. You know, a lot of these devices seem "unworkable", like a generator that powers itself. But by studying Lenz's law, we may find that "100% efficient" is not as efficient as we think it is. Look at the illustration. At the bottom, I rotated the coils so the emf would be in the same direction. Now notice that the emf produced with a North approaching, and a North leaving is the same as a North and South approaching at the same time...   ??? Looks like modern generators might be grossly inefficient.
