0 Members and 39 Guests are viewing this topic.
ALVARO_CS
Hummm
51 downloads in less that 24 hours !
It seems that RandyFL is not the only one thinking about it.
At least I´m happy that my work could be useful for someone  :)
Doug1
Not bad Alvero, a little bit word'y in the beginning. You have some type o's to fix but over all not bad. That is my version of a compliment. It would probably be better suited as a historical read over a manual. There are a lot of details left out regarding specific coil techniques of the inducer magnets. The resister array is spot on but there are problems with getting a person to mentally visualize it from a written description.  You did not mention anything about the current in the inducer of decline at any given time. The semi collapsing field will send current back into the array as it declines while at the same time reversing the polarity of the declining inducer.An electromagnet is also a storage device. For a short period of time this places the two inducers in an opposing field orientation nn ss after which the array is starting to move current into the opposite coil. A fair amount of the power is just shuttled back and forth through the array and boosted a little bit from a small amount off the output as it goes through the distributor.
   The advantage of paying attention to the turns ratio of the coils is the means to make a variable and powerful magnet no mater what the voltage you have to work with. You don't have to rely on using wire resistance to reduce the power consumption,the array will do it. So you can take full advantage using shorter coils in parallel to reach the volt turns ratio compared to the core dimensions covered. The Henry electromagnet should come to mind. A platter magnet might be a little better but they take soooo long to make.Lot of wasted material.
   Im going to ask you qualifying question. Does it need a rectifier?
ALVARO_CS
wowow Doug1, hold on a minute  !
I stated in my translator notes, that I was being as LITERAL as I could.
These are the patent words by Buforn, not mine !!!
IMHO its the  more tedious, repetitive, and obscure text I´ve never read in a patent. (I even found typos and spelling mistakes)
It is so even in Spanish, but someone here was using a worse program translation, and asked for a better option.
The simplicity of text in the Figuera patents, leaves many unknowns, but no booooring  :'(
By the way,. . what´s a semi collapsing field ?? . . . will it send semi current back as it semi decays ?? and will it semi reverse the polarity  ?? ;D ;D ;D (sorry, could not resist, no offense intended)
About my typo´s, please be kind to point them at me (in a PM) to be corrected asap. Thanks
cheers
Alvaro
MagnaProp
Quote from: ALVARO_CS on August 01, 2015, 11:00:32 AM..It seems that RandyFL is not the only one thinking about it...
Thanks for the translation.
I am trying to make sense of how it is wired together. The patent drawings don't appear to be clear on what wires are passing over others and which ones are connected together. Are all intersecting lines assumed to be connected together?
Attached is my attempt at which wires are connected together and which ones are not by pure guessing. Color coded only for clarity. The green dots are wires connected together and the yellow arch is where two wires pass each other but are not connected.
I have included a clean image so that you or someone can hopefully draw the connections correctly for me.
core
