marathonman
Thanks Hannon and yes i am fine.
actually this control system will be used for my stationary Dynamo i have designed because the resistors i was using got to hot with 100 volts 1-2 amps so i had to come up with something else. i just thought i could use it for Figueras design.
i took a 1900 rotating Dynamo and made it stationary using electromagnets....just waiting for the funds to purchase the Iron Core.
I have racked my brain with Figueras device when not on other projects hoping myself or some one else would crack this 100 year old puzzle.
HAPPY FIGUERING
marathonman
I think i have solved the Figueras 100 year old dilemma. last night at work i had an Epiphany. see i am working on a stationary Dynamo for my self just to say i did this but last night i realized that i had Inadvertently solved the Figueras Patent. i will draw out my findings and present them to everyone when i am finished. you will just soil your self ....it was right in front of our eyes the whole time.
HANNON..... here is the control system for Figueras using mag amps for control..... NO RESISTORS to waste electricity.
all you have to do is connect them opposite of each other and you will have mag amp control.
truesearch
forest
FINALLY !  ;)  Hard to believe it took you guys so much time ...
marathonman
Now just remember figueras took a rotating Dynamo and made it stationary so this means he had to put a Electromagnet at every station then he straightened  it out length wise then cut the core in pieces. but you must not forget that the original Dynamo had a north every other coil and the south every other coil so to get the reversing flux through the core as it turned.... so this has been forgotten in the process and also EVERYONE was wiring the whole thing wrong.
the pic below....all the RED dots are fired together and all the Blue Squares are fired together to get the original rotating Dynamo sequence of the reversal of the flux. "THIS IS A MUST AND CAN NOT BE ANY OTHER WAY" or it will not work
NOW look at the output coils "SEE HOW THEY ARE WOUND" one section is wired with the end of the coil on top and the next set is wired on the bottom then it is repeated in pairs AS IN TWO.
Dynamos and Figueras devise will always end in South....you can not just add one you have to add two to get the north south coils.
as for the timing.... this will be up to you but for myself i will go for the mag amp control with no resistors.
Just remember Figueras Devise never reached ZERO VOLTS... he switched it at mid point
YOU ARE WELCOME EVERYBODY!
FIGUERAS ROCKS!
