0 Members and 36 Guests are viewing this topic.
marathonman
Doug1; i decided to post it any ways.
This is what i am referring to Hanon,
when the North Magnet/Electromagnet is approaching the core pic #1 currant is flowing down left side of coil.
when South Magnet/Electromagnet is Approaching the core pic #2 currant is flowing up left side of coil.{opposite with same side}
now take South Approaching Magnet/Electromagnet around the other end of the North Approaching Magnet/Electromagnet now the Currant/B Fields/Polarity are the same, complimenting one another.
when you do the same with the #3 and #4 Receding Magnets/Electromagnets you will get the same thing at opposite polarity with currant?B Fields/Polarity the same, complimenting one another.
so that leads me to Pic #5 at bottom  one set Approaching and one set Receding, complimenting each other.
Doug1
One non matal ruler two magnets and one coil of wire connected to a mutli meter will go a long way.
antijon
Well, did some general tests on perpendicular coil last night. Working on the basis that says a changing B field perpendicular to a coil produces current, I found bumkiss. When the coil is perfectly centered and flat against the electromagnet, and the B field is uniform, zero current flows.
The Canadian patent is non-working unless he uses a foreign coil wrapping technique different from a typical solenoid. Apparently, he also confused the difference between a moving and non-moving magnetic field.
norman6538
Marathonman your drawing made it clear but I need the wording to finish my understand completely. So here it is.
Today is truely a great day for alternate energy.
Refer to fig. 5 in this message.
http://overunity.com/12794/re-inventing-the-wheel-part1-clemente_figuera-the-infinite-energy-machine/msg464191/#msg464191
As we know when current flows there will be a push back/Lenz counter to motion force
and that force in this drawing will be counter balanced by the N to S magnetic attraction.
I suggest
1. a flat coil because you do not want to go inside the coil and you do not want to
get super close where you have an attraction sticky spot
2. mount two magnets per fig 5 on a scissors ends so that they can
simultaneously can approach and leave equally.
3. and if that force is not equal two repelling magnets of a proper matched force
    on the other ends could match up/balance the Lenz and magnet attraction force.
4. to test this drive it with a weight on a string/connecting rod and run 2 tests
     a. no current flowing and b.  with the coil shorted.
   The times should be the same if this idea works.
This setup is not a NO LENZ generator but a magnetically balanced generator.
This means we can generate either 1 watt or 100 watts for only the mechanical work
to move the mechanism.
This is a new day for sure.
Thanks Marathonman for your dilligence to get my mind to understand the principle.
I think there is a problem when the magnet leaves because Lenz will resist leaving
like the  attracting magnets resist separation but that can be handled with repel balancing also.
Norman
