Schiko
@Hanon
Could you explain why you thought the similarity between two patents?  ???
I have not seen!  :-[
In my mind patent 1908 has three aspects
1 - Reluctance
2 - increased electromagnetic section
3 - symmetry between the tensions of the primary lagged 180 degrees
Simple as a generator!  8)
For me the problem is to find the best ratio between primary and secondary inductance because it directly affects the resonance frequency of the magnetic assembly where the phenomenon occurs.
LF, HF will work no matter it all depends on the coils  ;D
There is an advantage of electronic commutator, adjust the frequency to any type of coil.
If you'll work fixed at 60Hz prepare for the difficulties of tuning coils  ;)
ariovaldo
That makes sense and I do think we have something here. Air gap, very small one. Don't you guys think we can use dc coil instead permanent magnetic?
Schiko
Quote from: ariovaldo on September 25, 2013, 03:01:36 PM
Yes... air gap = reluctance
The machine of Mr. Figuera magneto is not necessary, in my case fumbled more than helped ...
If you observe the threshold of the negative peak of the sine wave never goes to zero volts, coils always a small current, adjust the threshold in your case is more difficult to increase or decrease the value of the resistors.
Find the right point helps the phenomenon I experienced this!  ;)
ps: when you arrive at the point of work, the cores will stay super magnetized!!!
abraço!
bajac
Hanon,
I am sorry for the misunderstanding. I was referring to the performances between the device I disclosed and the device found in Carlos' patent.
I can only speculate that Carlos and I had the same reasoning, BECAUSE THE ENERGY MUST COME FROM A SOMEWHERE, A PERMANENT MAGNET WAS REQUIRED TO PROVIDE THE ENERGY SOURCE. However, Figuera and Tesla showed us that there are other more powerful energy sources that we just do not know about it. Figuera and Tesla taught us how to extract infinite amount of free energy from wires
Suppression or not, The truth is that these types of energy sources have been hidden from us for too long.
Regards,
Bajac
Schiko
@bajac
Bajac you did not answer if you have finished your H-bridge???
So I am waiting for your tests.
I do not have large coils to test!
cheers!
