0 Members and 61 Guests are viewing this topic.
NRamaswami
Noypi:
High Frequency currents are beneficial. If you have had problems then you were sending the current in way that was injurious to you and one thing you could have done is to reverse the direction of current flow in Tesla coil.
Frequencies between 1.6 Mhz to 9.6 Mhz are inimical to human body. You have to avoid them.
Frequencies of 20000 to 40000 Hz are beneficial to human body but you cannot give them directly but would have to give through an air core solenoid to create a high frequency magnetic field. Then the part of the body affected should be placed in the air core coil and this will cure problems like Tennis Elbow Knee Pain etc. If you use square wave high frequency input it will kill parasites, viruses.
Please read the strong pdf and Hulda Clark Pdf.
Marathonman:
That Junk circuit I posted is the full Figuera circuit.
Please see this page http://www.alpoma.net/tecob/?page_id=8258
As seen in the drawing the current, once that has made its function, returns to the generator where taken; naturally in every revolution of the brush will be a change of sign in the induced current; but a switch will do it continuous if wanted.  From this current is derived a small part to excite the machine converting it in self-exciting and to operate the small motor which moves the brush and the switch; the external current supply, this is the feeding current, is removed and the machine continue working without any help indefinitely
Instead of current splitting rotary device and DC motor and battery I have used Diode Bridge. Using diode bridge with a specific circuit arrangement will result in Full wave positive wave input which is always above +5 and would also provide a variable high frequency input. We need to give it just once from the Circuit. I have also built the circuit. We are going to modify the circuit to provide 500 volts input with milliamps and about 1000 Hz or more of input frequency.
What I provided is the exact Figuera circuit. We have removed the rotary brush and the wear and tear of the part. That is an improvement over the Figuera device. No moving parts any where.
I'm sure you would disagree but study carefully.  See Figuera uses a small part of the induced current to make the machine self oscillating. That is what the circuit shows. The transformer is considered better than using a capacitor but a Run capacitor should work.
Doug1
Ramaswami
I have no interest in building a tesla coil if your speaking about the lightning machine. It is easy to follow directions for small ones used for demonstration purposes easy enough to find online. Your getting a bit scattered like kid in a candy store alone. The more you eat the more cranked up and scattered you get the more your looking to eat.
   Your lack of focus will end with an injury as you attempt to mix the wrong things together out of frustration and or confusion. You need a vacation with your family or who ever you care about the most to re-establish your priorities. I make no apology for being blunt. I really doubt I am the first one who said something to you to this effect.
ignacio
Mezclar, escribir textos largos, tergiversar, se usa para que las personas, no puedan prestar atención, al principio expuesto, muchos lo hacen para proteger su trabajo (sus posibles patentes) ¿?
<<Clemente Figuera: reproducir un Generador eléctrico, con las piezas inmóviles.>>
Mix, write long texts, misrepresenting, is used so that people can not pay attention at first exposure, many do to protect your work (possible patents)?
<<Figuera Clemente: Playing an electric generator, with stationary parts.>>
Ah, Gracias por el premio, (mierda de burro)
Ah, thanks for the award, (shit donkey)
marathonman
well since we know, well some of us that the rotating part G is a Rheostat/Varidc to vary the currant with magnetic field, why can't we use transistors to mimic the rotation of the brush and not have to use real resistors or diodes.
the first pic is my interpretation of the Part G with explanation of its use.
second pic not showing all transistors can be used to mimic rotation and still get the effects of the same device used, using magnetic's to vary the currant while still retaining the feature of being able to receive the declining electromagnet's kick back in the form of magnetic storage and not have resistors or diodes get in the way.
Figuera even said that switches can be used instead, so the transistors are the switches.
ignacio
Mejorando, Problemas: hay que usar transistores, que aguanten 3 amp. Y circuitos electrónicos, difícil para mucha gente.
you're improving,, Problems: need to use transistors that can withstand 3 amps. And electronic circuits difficult for many people..
