0 Members and 53 Guests are viewing this topic.
Doug1
Quote from: shylo on March 25, 2016, 07:33:42 PM
What if you did 36 alterations per minute?
It should still work right?  As long as there is a change of state, the period of time it takes shouldn't matter should it?
artv
In the sense of functioning yes but it will not be very useful except to make a blinky light that goes on and off at almost 2 sec intervals.
marathonman
Quote from: hanon on March 24, 2016, 02:17:39 PM
Marathon,
I think now I get it. Thanks for sharing this info.
I found this link: http://sound.westhost.com/articles/variac.htm
"Unlike any normal transformer, a Variac can be used with DC, although it is nothing more than a "rheostat" or variable resistor"
The best design, at this stage, is the simplest one, so that a greater number of people may build it.
Hanon;
The break down is in transfer of information because most people here still think a Rheostat or Variac/Varidc are using resistance to alter the voltage and currant in which this is not the case.
magnetic field and intensity i(Reluctance) is used to control the currant of both devices above. as more winding's are involved it has higher magnetic field  in the core (Reluctance) resistance to change in currant. as the brush rotates closer to Set N less winding's are involved so that means less magnetic field in the core, less reluctance, less resistance to currant flow to set N and the currant going in the opposite direction to set S will have more winding's, higher magnetic field, higher reluctance, higher resistance to currant flow.
that is why i chose to give example in the pic i posted to give someone a better view on the Figuera part G but apparently all that happened was the focus on the pic used instead of the operation of the device
so if one was to study the Rheostat or variac's correct operation then one's outlook on Figuera's part G will come into focus.
hanon
Look at the new chapter in PJK ebook. Maybe you will note many "deja vu" to our lovely Figuera NN design:
http://www.free-energy-info.co.uk/Chapt22.html
(link dedicated to the still un-believers)
Marathonman, It is great to see those good ideas explained with visual sketches so that we may get the idea. I really see a possible improvement to avoid wasting energy as heat. In my case I wont even regret in wasting those 100 input watts in common resistors if I could get back just another 100 watts.
