0 Members and 139 Guests are viewing this topic.
forest
Mr Ramaswami
Here is the Truth: "a machine which produces large industrial electrical currents which until now cannot be obtained but transforming mechanical work into electricity."  Not a single generator in history was converting mechanical energy into electricity and the total pollution and green gases emission and the whole multi-billion "worth" industry is a piece of CRAP. This energy is wasted, completely lost in the job of breaking the natural occurrence of magnetic dipoles in generators. Exactly and precisely it was first explained by Clemente Figuera (maybe because those patents were prevented from destruction). I know that this was not the oldest attempt to explain faulty generators. Daniel McFarland Cook tried to patent his generator obviously based on the same ideas. Ed Leedscalnin talked about the same and so on.... Hidden knowledge perpetually covered from the times of Faraday.
P.S. I have a question to those of you who knew electronics. If I make a transistor amplifier to amplify small sinewave from a Wien bridge oscillator into a 100V 1A current still sinewave, would the inductance react with reactance to this one as to the ordinary sinewave current from grid ? Let's imagine a single transistor amplifier connected to the 100V DC source and driven by a signal from such a generator. Somebody ?
NRamaswami
Mr. Forest:
I apologize to beg to disagree with you. If what you say is the truth, ( I would accept it, if and only if) please describe a simple device that can generate Electricity without these wastage. Please do not say Figuera for there is not a single Figuera device shown operating as described by Figuera.
Please do not say Cook for one person who indicated he has built a Cook device refused to answer me and there is no known cook device.
You please describe a simple device that can work without mechanical motion and can produce more output than input. I will then try to replicate it and see if it works or not. If it works Great. I validate your device and replicate it and it also becomes open source. Right?
I have conducted hundreds of experiments for more than 3 years now. I have concluded that there are at least two types of fundamental particles associated with Electricity. One is very small particle that can travel very fast and likes material with lot of resistance. This particle is responsible for Voltage. The other particle is comparatively very thick and can capture and hold a lot of charge and can release the charge but it requires material with low resistance and it needs thicker wires. Thicker the wire better it is. I have produced 500 volts or more in the secondary with some type of coils and you connect it to load the voltage drops to zero if there is no amperage. Because the coils can be made to block the movement of the particle that causes amperage. There are other coils that can light 10x200 watts lamps or more even at 30 volts and higher the voltage brighter the light and hotter the lamp. I have already posted the pictures of some experiments.
I do not want simple statements and I'm prepared to accept statements. Back it up with a simple device that can be made by people. I agree from my experiments that Figueras principle is correct.
There is yet another member in the forum who has indicated he has built a self sustaining device.  He can also tell us.
It will be very difficult for me to do these experiments myself and I have to ask some students to do it. So if you have any device that you have already tested say it in the forum but if you do not have any thing working,,except some conspiracy theories how can I believe your words? Pray tell me. Please do not tell me about any non working device as it will be a waste of my time, effort and money. If you do not have any such device let us see if others describe any such device.
Let me try my hand at this if no one can describe after a few weeks.
Sir..Erfinder I always try to learn from other people. I have no intention or competence to argue. I keep my mind open and try to learn always.
That said I can confirm What Mr. Marathonman indicated about magnetic research.  There is only one advanced Magnetics lab for Research and it is in US. Only prior vetted competent people can enter that. There is no funding for Magnetics research in India after 1940 so much so that this area lacks competence in India right now. I can confirm all this is true.
cliff33
Forest:
I am assuming  you'll be driving just ONE of the primary coils at 100v/1A with 60hz sine wave. Then I would say "yes" the output would be like
that from the grid.  But why try to replicate an ordinary transformer?
   Because there are TWO primary coils to be pulsed, then you will need two separate amplifiers.
I'll be using a wien bridge oscillator to drive two different transistor amplifiers. A type npn and a type pnp.
Study the "G" switching diagram to give you a better idea as to what needs to be done.
Marathon:
Yah, I threw those 10 bad transistors into the garbage along with that broken LP record lol.
forest
Quote from: cliff33 on May 14, 2016, 12:42:40 PM
Forest:
Cliff33
That's exactly what I want to do  :)  Two amplifiers and two sinewave signals. First I will try single sinewave with other circuit, I was simply not sure if the coil will react to this amplified signal with reactance or not. I knwo that simply using diode bridge will nullify reactance and coil only react to the first change of DC current. I need sinewave of any chosen frequency for LC circuit also (another related project).Thanks for confirmation.
Do you have schematic with two transistor amplifiers ? I suppose transistors should have the same Hfe
marathonman
Cliff; LP record is hilarious Transistors are not, sorry you got taken. i have some new 2N3055's you can have, with heat sinks.
Just for future info the field of an AC coil can not build up fast enough in the Figuera device unlike DC low ohm's that is lightning fast. just saying !
