0 Members and 25 Guests are viewing this topic.
seaad
Quote from: marathonman on May 04, 2018, 01:15:20 PM
Sead; Actually that which is in the orange ring is actually sliding adjustments as to balance the primaries from peak to peak. minor oversite that is it nothing more nothing less.
Marathonman
Why a double twisted? wire to each side of the G-part? How are these connected to the  G and S, N components? And you have both + and - brushes now rotating on the G-part. Not the figuera style, OR?
Regards Arne
marathonman
Seaad;
  I actually do apologize for the blunder as i was getting the point across of the brushes and the magnetic fields associated with them and only added more confusion in my attempt to convey my point and for that i am sorry. those twisted wires are actually not there as that is the continuous wind on part G. those connection shown are actually in the middle of part G as you are winding it and will not be seen.
the adjustable connectors below are advisable to allow the adjustment of the balancing of the primaries. keeping things adjustable will help in the final tweeking process.
flipping the tab allows the connector to be used in a much better way allowing it to be slid on the wire for adjustments. the first pic is the connector stock while the second pic has the tab flipped allowing it to be slid on the wire for adjustment of the primaries balance.
the second brush is the secondary output looped back to part G through a commutator allowing the negative and positive sides to remain their sign. this allows part G to be the power supply once the starting power is removed. in essence part G becomes the amplifier of the signal as all released potential of the reducing side is combined in part G giving an amplification to the rising primary.
all magnetic fields when reduced releases that reduced potential into the system and this is a Physical fact not fiction and can not be disputed by no one.
Marathonman
marathonman
Quote;
"marathonman
"Thank you" seems inadequate. What is missing from most forums is someone who is unselfish enough to share ALL their research and discoveries for the betterment of mankind. On this site there is none of that, only like minded people who want to see man progress.  I have had this patent saved for a lot of years and understood the basics of how it works, but thanks to your work i may someday be able to make it work. Thank you again.
Tony" end quote.
I get messages like this all the time from people that are not only interested in this device but want to learn how to build it. i share all my work freely and hide nothing.
but on this site all there seems to be is people who want to argue and belittle people i guess to make them selves feel better from something that is lacking in their life, i don't know.
all you have to do is read and understand what has been posted then verify that by yourself.
This is a quote from Aubrey Scoons that replicated Royal Rife's work;
"DON'T BE FOOLED!
Complexity does not equal credibility. Just the opposite in fact. Anyone who has genuine insight will be able to explain to you in simple language exactly what they mean and you will then be able to verify it with known scientific fact. If they can't.....well, what do you think?"
This is why i choose to explain things in detail but at a level everyone can understand. read what that said again  "and you will then be able to verify it with known scientific fact."
THAT MEANS YOU PEOPLE. if you don't take the time to research and conduct test to verify what is been said then what are you doing here in the first place other than causing havoc and disrupting threads.
this as far as i can tell is suppose to be a place to learn not sharpen your battle skills.
we live in a perpetual motion machine but since we are on the inside looking out we can not see this just like the fish in the water inside looking out.
if perpetual motion is not possible then wouldn't it be awkward if the world stop spinning tomorrow. not likely as it will continue billions of years after we are gone.
Marathonman
marathonman
Studying inductors , Self-Inductance, Inductive Reactance,  how, why they work and the actual reasons for the currant reduction will help in understanding part G. also understanding how boost converters work will also help in your journey. once you learn the currant travels in the same direction it was traveling in the first place you will them be open to the possibilities of an static inductor being used in an active state kept in an active state from the constant brush rotation. all reduced magnetic potentials are combined in part G giving rise to amplification to the rising primary electromagnet and rising side of part G.
these are just the consequences of induction from the laws of induction laid down by Michael Faraday and the rules from Heinrich Lenz.
Marathonman
seaad
History two years back:
http://www.energeticforum.com/renewable-energy/12439-re-inventing-wheel-part1-clemente_figuera-37.html#post292732
Which one is valid today?
1:st pic. CW and CCW , 2:nd pic  All windings CW - OR !- CCW , 3:rd pic (MM:s today)  All windings CW -OR- CCW
Regards  Arne
