0 Members and 42 Guests are viewing this topic.
forest
If you guys have ability to contruct real generator from scratch or at least heavily modify existing ones I suggest to fist follow Figuera path and modify existing generator like Figuera did in 1902. You cannot fly if you didn't learned how to stand up.
marathonman
Good God this thread is following the 1908 patent if you can follow that. do you people smoke something on a daily basis or what.?
Follow the 1908 patent and you just might get some where.....maybe !
you people are as bad as EF.  what do you get when you increase a magnetic field of the left electromagnet while decreasing the one on the right.... it is called coherence of the Electric fields meaning they are in the same direction.
This is Crayola Physics people and if you can not follow that just maybe you need to pick another device.
regards.
Marathonman
ourbobby
Hi marathonman,
                          I have taken the attached - very profound - quote from another forum where you posted. My question is, are you talking about an electromagnet or a fixed domain magnet?
Regards ourbobby
Quote" even though a magnetic field is created around[/font][/size] a conductor when currant is flowing it is at right angles to the currant flow but the electric field is parallel  to the currant flow at all times.  when a magnet is brought close to a coil of wire we were told by our forefather in Physics that the change in a magnetic field causes currant to flow. what people do not understand is a magnet is an electrified object with domains locked into place causing a constant currant flow around the magnet it's self. [/font][/size]the currant flowing in the magnet is what is causing the electric field of varying degrees of intensity so when you bring that so called magnet into a coil of wire what you are really doing is changing the intensity of the electric field intensity around the wire which causes currant to flow. the magnetic field has nothing to do with the generation of currant what so ever and is just the resistance to the electric field."[/font][/size]
[/color][/font]
Edit: I do not think that I will ever forget that explanation!
marathonman
Yes i am referring to a magnet but according to D.B. Larsen which makes a whole lot of sense to me says " gravitation has a three dimensional aspect ie in three opposite directions that cancel out each other. when a two dimensional magnetism is introduced it cancels out two of the dimensions of gravitation leaving one dimension of gravitation 90 degrees from magnetism which flows from counter space into space. magnetism is the controlling mechanism to current flow and when you exceed this you have wires burn.
a magnet is an electrified dielectric object which has current permanently looping around it's perimeter with it's domains locked into place.
I hope this makes sense to you as it does to me.
Marathonman
ourbobby
Hi marathonman,
                         Further to my post above, and regards to flux cutting and flux linking. And, from the comments on another site and the Ferranti generator. I can see where, as you pointed out previously about Walter Russell Coils, that Russell advocated the alternate direction of motor/generator direction to that generally in use in today's motors/generators. In a Patent, Ferranti ideally shows a form of Homopolar mechanism cutting through peripheral coils, not unlike one proposed by Russell, who incidentally suggested that he could get up to 300 fold output. Understanding this phenomena is proving to be intriguing. As it is said, the devil is in the detail. The similarities of many devices.
Thanks for your comments.
Edit, well I uploaded the optical generator of Russell's, which looks like a copy of a Ferranti Generator. but, it loaded as massive. Not sure how to manage that.Anyway it was more for other interested members as I suspect you might be familiar with it.
Dwane
