Bridging coil to extend the magnetic field of strong magnet
Started by bs2012, October 10, 2012, 07:15:20 AM
bs2012
Just come up with an idea:
- put a strong magnet besides a generator coil
- the generator should outside the magnetic field of the strong magnet
- put a bridging coil in between the strong magnet and the generator coil
- power up the bridging coil with pulse, magnetise the coil in opposite pole to the strong magnet
- the magnetic field from the strong magnet could then inducted to the generator coil
- collect power from the generator coil
Please comment this set up.
cristache
Will not work. Here is why
Assume the generator coil has magnetic field from the magnet.
When you put energy into the bridge coil to reduce the field in the generator core, the induced voltage in the generator coil will have such a direction to oppose the flux reduction, so your bridge coil will have to compensate for that - more energy
What you get is a sort of transformer, with your bridge coil being the primary and generator coil being the secondary with the field biased by the permanent magnet.
And is an inefficient transformer since the magnetic flux is not closed into itself and there is a lot of flux leakage.
bs2012
Hi cristache,
Quote from: cristache on October 10, 2012, 09:23:29 PM
Seems you have missed my assumption that the generator coil is positioned outside the magnetic field from the magnet. :)
Only when energy is put into the bridging coil, the magnetic field from magnet could reach the generator coil.
What the generator coil could get is the magnetic field from the bridging coil plus the magnetic field inducted from the magnet.
cristache
Still a very inefficient biased transformer.
Use Femm 4.2 to simulate. You will see you will have to put A LOT of energy into the control coil if the core is air.
If the core is iron the magnetic field of permanent magnet will penetrate the core
Either way you get the same thing
TechStuf
Get some hands on BS....You're thinking outside the box.  You need to think with one hemisphere inside and one outside the box.  Your work would bear more fruit if you combine a halbach ring, a magnetic beam amplifier, and a coil of correct geometry.
TS
“For the wisdom of this world is foolishness before God. For it is written, “He is THE ONE WHO CATCHES THE WISE IN THEIR CRAFTINESS” - 1 Corinthians 3:19
http://www.freemasonrywatch.org/sixpointedstar.html
http://www.youtube.com/watch?v=XBjOs-egFMs
http://www.youtube.com/watch?v=_WSGwnz7XpY
http://www.youtube.com/watch?v=l39XsMcyvgA
http://portland.indymedia.org/en/2004/09/297062.shtml
http://www.youtube.com/watch?v=JjjIy1DO0gs
We all have the choice to waste ourselves in rebellion or to gain wisdom.  Therefore, gain wisdom:
http://www.hisremnant.org/eby/articles/kingdom/twohands/twohandsof.html
