New lifter design in progress
Started by Sojourner, April 01, 2005, 10:44:33 PM
0 Members and 2041 Guests are viewing this topic.
cmichaelcouch
Soj:
Are you talking about a plane with a lifter driving it?  Or a normal lifter?
My pet idea which no one has tried yet and I'm not ready to try yet, is to figure a way to use the crystal shock HV like in the Charcoal fire starters.  I've read that they generate 9000V.
Michael Couch
Sojourner
As far as winged craft:
I have considered that for a while now and plan to make one, but I also want to make it with vertical take-off,  I'm doing experiments now to test enhancing the ion propulsion and incorporating it with normal airlift.
Thinking of a design though that looked nice and could do both is the hard part, LOL I want something that when people see it take off, they go, "Holy S$%$%!!!!!"
I also want to try to get a speed faster than 3.5 mph. It seems no matter WHAT I build on whatever way, my speed can't go faster than that.  My 'guess' on this is the voltage.  I need a higher potential and get the anode futher from the cathode to take advantage of the intertia.
As far as quartz:
From what I understand, they take a tremedous amount of shock to create power. Think of the pressure it takes to push down and 'click' a charcoal starter or even a piezo lighter. It really slams hard!. I would think doing the slamming part would be hard.
The burst only last billiseconds too. Then there is the weight of the crystals to consider unless you utilize other technology to counterballast.
Soj
raburgeson
Maybe we can mix technologies , I hear gyros can lighten loads. I have a problem with stability and it may help.
Think you are right about the voltage I remember reading T T brown was going to produce a large disk I
believe it was 10 foot and 100kv if I'm wrong it would be 300kv. Think it was in the book "In Search of
Zero Point Energy". I read so much anymore I can"t be sure exactly were it came from for sure. If you haven't
read this book yet your in for a treat. Have you tried setting the skirts about 22.5 Degrees to create side thrust?
Hex shape  should work for this idea well.Tried to help with coil subject.
iceweller
  Are you referring to "The Hunt for zero point" by Nick Cook or "Quest for zero point energy" by Moray B King? The book by Nick Cook (Janes) is nothing special and simply creates more confusion (which is what I believe it was published for).
  Maybe, you should take a look at "Occult Ether Physics" by William Lyne.
Sojourner
Quote from: raburgeson on April 16, 2005, 08:21:44 PM
I will be using multiple technologies. My model craft will be hollow and will use helium to counter the weight of the craft and the power sources. The wingspan is guestimated at about ten feet wide. I'll be narrowing that down as soon as I am satisfied with the power plant and get its total weight. .......along with (maybe) a camera.
I'm right int he middle of moving tot another town, so many of my projects are on hold right now.
SOj
