Crystal Cell Research
Started by plengo, October 29, 2012, 06:08:15 PM
drodenbe
here are the types of coils I am using for the joule thief circuit.  They are line input filter chokes.  I get them out of old tv sets and power supplies.
David
4Tesla
I've done some research on TSP/90.  Red Devil's version isn't pure Sodium Metasilicate.  It is Sodium Metasilicate Pentahydrate.  This is known to prevent corrosion on metal.  8)
plengo
Quote from: 4Tesla on September 27, 2014, 09:43:37 PM
I was able to buy that PURE at ebay once.
plengo
I almost forgot to share undeniable evidence in favor of a non corrosive cell (at least that's how I see it, if someone knows more, PLEASE, bring arguments that will clarify my mistake).
I took one of my one-cell, casted, into the freezer and let it there for a few hours. Before that the voltage under 100 ohm load was around 7.6 mv or so.
After removing from the freezer I measure its temperature and it was below 10 Celsius degrees (-11 to be exact) and the running voltage across the 100 ohm resistor was .2 mv and slowly went to .5 mv (-10 Celcius) and to 1mv (-3 Celcius) and to 2 and to 3mv and still growing, last measure was 7.83 mv and growing.
Moral of the story: I believe that at below water freezing point there would be no corrosion possible since water would be , obviously, frozen prohibiting ion flow. No ion flow, no galvanic reaction or REDOX. It is possible to have corrosion (oxidation for example) but not having electrical current flow as a byproduct just like a regular battery would.
A capacitor I would think would be still discharging under this low temperature but it is a capacitor and not a chemical reaction of sorts.
Anyone to give some input?
Fausto.
profitis
your on the right track plengo but freezing is definitely not the way to eliminate possibility of corrosion.corrosion will happen even close to zero kelvin so long as air-moisture and o2 is available.one way to check for zero corrosion is to do the stepdown-spillover test that I did in karpen thread and it must be done rapidly.the other way is to get spontaneous REVERSE-POTENTIALS as I showed in other thread.you are absolute correct,we want the electrochemical voltage potential,not the corrosion.check out what happens in a photoelectrochemical system,you get eg, the iodine redox-system going like this at one electrode I2 + 2e- = 2 I- and reverse at other while light falls on one electrode.so the redox system is just acting like a see-through copper-sheet conductor.
