Crystal Cell Research
Started by plengo, October 29, 2012, 06:08:15 PM
Billynjamie
When you freeze things they expand right. So that would increase the internal pressure. Hence your slight rise in voltage. My YouTube channel is under BackRoomLabs. I have replicated John Bedinis high pressure cell with a shop press and yes the more pressure the higher the voltage. I have no idea why but pressure seem to make a little higher voltage. How does the current differe from frozen to none frozen as I have never tried freezing my cells?
profitis
Freezing lowers internal resistance loss.
profitis
Freezing also lowers self-discharge voltage loss
profitis
Freezing condenses moisture from the air
plengo
Quote from: Billynjamie on October 14, 2014, 04:25:37 PM
May be it is pressure BUT i tested another 2 cells and they behave more like I expected, colder, less power output. Those 2 cells did not form the crystal well before I closed the cell.
So I have 2 exact same tests with total different results same formula different growth crystal levels.
I am puzzled myself.
Fausto.
