Friction heater running in my house
Started by oilpiggy, October 31, 2012, 02:25:24 PM
Doug1
 Patents can be design spicific he made enough improvements to get one through. Hopefully he didnt give up everything in his video or the chineese will have them already loaded on cargo containers ready to ship by now.
  Last time I tried to make a friction heater it didnt put out as well as I wanted it to so I dropped it. If I ever go back to the drawing board it wont be based on liquid friction. Magnetic induction is a lot less messy.
  It's a nice build you did a good job. I think you could market them easy enough if you scale them to fit an RV or a long hual semi tractor trailer since they are expanding the no idle laws every year. Commercial and recreational markets have a higher margin then residential markets. Good way to get your feet wet without drowning right out of the gate.
ramset
OP
I hope you didn't use the Atom  word in your patent text?
They have a very big "Atom stick" at the Patent office . [never give a man a stick to beat you with].
I also noticed lately they scrutinize things a bit closer than in the past.Prior art Etc. Etc.         {Rossi}
We don't really play "patent" here, which i suppose you already know [Forum Title}.
your willingness to share is wonderful !
Thx
Chet
Thanks Grandma
Chet,
What happened to your friend's project that was a heater based on passing electrical current through water and using "resonance?"  I am assuming that the film was never made and the whole thing withered on the vine.  Am I correct?
In this case, why should an electrical motor turning some sort of friction device be any more efficient than an electric baseboard heater?  Both devices in the final analysis produce heat power.
You have electrical power going into an electrical motor.  The output from the motor is heat power and mechanical power.  The mechanical power from the motor goes into a cylindrical device that converts the mechanical power into heat power.  Do you see any place in this system for saving on your heating bill?
oilpiggy
Hello everyone
Just need to say this, I did not start this build with the intent to try to make money off of it. My goal was to stop seeing people go with out a very necessary thing like heat.
With that being said I would not mind it someone in China picked this up and ran with it, all that would mean is they could build it cheaper then me and more people would have it. Who knows maybe then you could just go down to walmart and buy one :o Hell I would buy one. ;D
And no I did not use the word Atom but that is what is happening. the molecules of the oils are trying to stay in one spot and this is making them move around making heat.
This concept is not a new one its how it is done is what makes it. I don't think by any means is it "OU" but It is a very cheap way for me to make heat.
I am working on drafting off some of the heat to make power to supply some of the power to make it run even cheaper.
Paul-R
Quote from: ZathEros on November 02, 2012, 12:25:59 AM
Patent?
Prior art already exists on this and is in public domain.
Yes. You should check prior art thoroughly before spending anything on a patent.
Page 9:
http://www.free-energy-info.com/Chapter14.pdf
