sulake
Quote from: AbbaRue on May 13, 2008, 05:08:31 AM
...I was thinking maybe connecting the output to a capacitor and then measure the voltage across it.
Has anyone come up with a solution to this?
Some measurements can be recorded with soundcard. This would show you forexample the difference between no-Bfield and with-Bfield pulse. You can not see any units (volts) but you can see exactly what is the difference between two setups (total power difference).
Normal soundcards have sample ratio of 44100Hz(22.67?s). You can use any small ferrite coil as a current transformer, like in the picture.
Put a resistor across the ferrite coil that you dont break your soundcard line-in with a HV pulse.
A good SounCard Scope with "single trigger" is found here http://zeitnitz.de/Christian/Scope/Scope_en.html
Feynman
CANCEL YOUR THORIATED TUNGSTEN ORDERS BOYS -- WE DONT NEED NO GAMMA
DEATZILS COMIN SOON
Koen1
* starts clicking like crazy to cancel order * ;)
:D
sparks
Quote from: Feynman on May 13, 2008, 01:35:27 PM
DEATZILS COMIN SOON
  No GAMMA just beta.  Magnetic disresonance of the 8th electron in conductor atomic fields by means of electron dipole shifting in response to an em wave will get you plenty of photons.  Earth's energy/mass will reset the 8th electron to it's proper energy orbital.
  Beta ray is just the electron hop from one energy shell to the other.  Carbon forms an elemental sharing of 4 electrons so therefore it takes alot more rf to elicit a mass to energy conversion.  Whereas conductors have a 7 proton configuration which involves a loose coupling of an eigth electron to fill the outer energy shell or go noble, or reach resonance.  Neuclear disresonance due to the nature of neutrons isn't a healthy thing to do.  We got enough neucleus crackers and spent fuel rods laying around emitting neutrinos to last us at least 20or 30 thousand years.  This shit needs to see a little rf to hasten the process of radio active decay.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
miki02131
Guys,
I am definitely interested in this topic. Matter-to-energy conversion is real and proven science. I have been researching it on several fronts. I am here to contribute and replicate.
In the meantime, be careful with the topic starter. He is actually located in Spain. He has robbed BAP of a few hundred dollars on a promise to build one of these devices that he never provided.
Thanks,
Miki.
