How does it feel to be duped?
Started by pauldude000, November 26, 2012, 06:43:54 AM
pauldude000
Quote from: Doug1 on November 30, 2012, 02:55:53 PM
So sort of like combining a Wimshurst generator and a dynomo or building a Wimhust overtop of a bipolar dynomo. You would still have figure out how to take the two outputs and convert it to something a motor could use to run it. It would take a creative transformer. More akin to a Y stator with varring winds and wire size for each leg of the Y with one of them as a final output to a drive motor. Then run some small pick ups over each leg of the Y as secondary  tie it to a Y configured light board to run some LED's and poof you got a flux capacitor. It may or may not work but it would be funny and thats whats really important. Everything works better with flashing lights.
Actually, it is not for the energy output per-say, but for the fields themselves and assorted field effects which might naturally follow. I think the goal was a localized small scale warpage of space-time. Use two or three fields to manipulate a central static field into something it couldn't accomplish by itself in nature.
Such a warpage would be inherently dangerous, to be somewhat understating the issue. I wonder if the notion was farmed out, so to speak, for that very reason.
Finding truth can be compared to panning for gold. It generally entails sifting a huge amount of material for each nugget found. Then checking each nugget found for valuable metal or fool's gold.
aether22
Is this meant to be the Nazi Bell, or another one?
Can one of you point to sources of information on this please?
So far this thread is just a tease.
aether22
This sounds similar, is this it? http://www.zamandayolculuk.com/cetinbal/htmldosya1/vriltechnology.htm
In the summer of the yearly 1922 at the first untertassenfoermigen flight ship, its drive on the implosion technology was built was based (the the other world flight machine). It consisted of a disk of eight meters diameters, over which a parallel-stored disk of six and a half meters of diameters was, and among them a further disk of seven meters diameters. These three disks were broken through in the center by a 1.80m measuring hole, in which the 2.40m high power supply unit was installed.[/size]
Down the centerbody ran out in a conical point, from which a pendulum handing into the basement provided for the stabilization of the equipment. In the activated condition the lower and the upper disk turned in direction moving in opposite directions, in order to develop first an electromagnetic rotation field. This first flight disk furnished which achievements, is unknown.[/size]
Restated in another text:[/size]
It had a disk eight metres across with a second disk with a diameter of six and a half metres above and a third disk of seven metres diameter below. These three disks had a whole at the centre of one metre eighty across in which the drive which was two meters forty high was mounted. At the bottom the central body was cone-shaped, and there a pendulum reaching the cellar was hung that served for stabilisation. In the activated state the top and bottom disk revolved in opposing directions to build up an electromaguetic rotating field.[/size]
[/size]
pauldude000
Quote from: aether22 on February 02, 2013, 02:34:21 PM
If I remember correctly, and someone correct me if I remember incorrectly, the nazi bell was supposed to be filled with red mercury with a dual layers spun up to high rpm's, each layer in opposing rotation to the other. Spinning mercury can generate mag fields so it may be a version, but it is not THE version of which I speak. Do research on the vril and thule societies. The supposedly proposed vril design is what I was talking about.
Whether the information is real or not, or whether you or I believe it possible, none of these matter. What is important is to remember that big companies and governments often spend large amounts of money on mere possibilities. The CIA, as a for instance, spent how much money on ESP? That should be a wake up call.
The disc Loner is talking about I am unfamiliar with, and must research myself. Thank you Loner.
Groundloop
Quote from: pauldude000 on February 03, 2013, 02:58:39 AM
Pauldude000,
The "Nazi Bell" was invented by Viktor Schauberger (1885-1958) while he was forced to work for the Nazi during WWII.
The device was based on wave patterns that modulated ordinary air to generate lift. As far as I know, there was
no mercury in the device. A good read is the book living water by Olof Alexandersson:
http://www.amazon.com/Living-Water-Schauberger-Secrets-Natural/dp/0717133907
Here is some pictures of the Repulsine device.
http://www.flickr.com/photos/esaruoho/4933936497/in/photostream/
Some more pictures:
http://www.laesieworks.com/ifo/lib/Viktor_Schauberger.html
Regards,
Groundloop.
