TK device, TPU.. Only enter if you seek truth. Cause here it is...
Started by elementSix, December 14, 2012, 07:26:31 PM
e2matrix
Quote from: elementSix on December 25, 2012, 05:25:18 PM
Nice explanation.  Thats what we need,  to keep the top spinning.  Thats what the 2 RF frequency's are for.  When we spin the Nucli from the low energy state to the high energy state, it becomes saturated and requires a different frequency to move it again.  Some spin from the higher energy state to the lower energy state.  It depends on the material.  But the different energy state nucli amounts are very close.  The lower energy state Nucli are a little more populous in the material than the higher energy state Nucli.  CW is the old form of NMR, which isn't nearly as powerful as the pulsed systems.  Does anyone think that using a wide band of RF signals at once can work as good as using just certain RF pulses that are the resonant frequency's?  Probably not.
Thanks for that clip slappy.  Have you looked at the RED and Mustafa Schematics?? I have problems using the Russian realstrannik forum with google translate.  I am going to PM the russian guy on the 5KW TK forum to help us figure out the Thyristors and diodes used in them.  Heres the Mustafa circuit.  Plus theres another from Russia that I'm not sure whats going on because its in Russian.
Can anyone translate the test on that 2nd circuit (3 watt in = 100 watt out) ?   I tried making it into PDF and OCR'ing it from Russian with PDF Xchange program (which translates with OCR) but no luck.
elementSix
I WOULD LIKE EVERYONE TO CREATE THIS CIRCUIT AND LET ME KNOW IF YOU CAN GET MORE THAN you put in  I have tried my best to describe the parts,  I don't have an oscilloscope for read outs. This circuit is nothing new, The resonance of L1 and L2 don't have to match, but they can if you can.. Uses a sine style wave with it.  I am pretty sure thats what it is but you can try others.   Let me know,  Don't go posting it everywhere, I don't want everyone blaming me because  they are idiots and can't figure out how to make this work..  Thank you and good luck
PS  the first resistor isn't really needed, I believe
elementSix
I Have been doing work with TESLA's patents that are labeled, "APPARATUS FOR PRODUCING CURRENTS OF HIGH FREQUENCY".  Which is the patents that Tariel Kapanadze got his device from.  It has to do with pulsing the negative and positive through a switching circuit at a very fast pace.  I was able to make my own version of the motor with contacts for pulsing the current through another transformer and I have gotten very good results.  Thats what TK's secret is.  Just Short Circuit Current.  The circuit above is the same thing basically.  So if you want to create a Solid State Generator.  Thats all you have to do.  It's not hard at all.  Just to get twice the Voltage out.   Below is just another picture from the Circuit performance above..
verpies
Quote from: elementSix on January 14, 2013, 10:26:22 PM
That looks like the DSRD pulsing circuit.  We already built it.
It works and it can produce nanosecond pulses in the 20kW range.
You can read about it here.
The I/O power ratio of this pulsing circuit is below 1 but it has been speculated that nanopulses produced by it can stimulate the BASER process in copper alloys to convert nuclear energy directly into electric energy.
verpies
Quote from: elementSix on January 15, 2013, 03:25:34 PM
Short Circuit current in a thick one-turn coil (e.g. a pipe or disk) stimulated by fast nanopulses and confined by a magnet is what McFreey is writing about.
Remember that twice voltage is not twice the power.
Increasing voltage by itself is not remarkable at all. Just about any transformer and inductor can do that.
