Magnetic energy pump OU motor
Started by wizkycho, August 05, 2006, 09:30:43 AM
wizkycho
new simulation !
coil wire: fi 0.5mm
400 wounds
1.5 ohm
coil-on: 0.7A
Input Power = 0.75727 Watts
This small 0.7W is making magnet to release huge 0.8T through rotor (through red line)
rotor is spaced 0.2mm from top and bottom (0.4mm air gap) of 1 stator core.
Igor
Perihelion Labs
wizkycho
This is real MEP generator. Will it work as FE generator ? Not only that !
I think it can propel rotor itself !!!
When rotor magnet is entering stator (it is attracted) arangement it makes magnetic field (field jumps from 0.06 to 0.9T).Then current is extracted. Lentz creates counter field that tries to repulse magnet.Lot of current can be extracted and still stator is NOT repulsing rotor magnet because there are two more magnet fileds.
Instead attraction only LOWERS (if not pushed to pedal), as we extract more current, making rotor magnet (that is now completely in stator) very easy to exit. It will exit easy scince attraction is low and attraction to next magnet rises because is different polarity and entering the stator with opposite lenz field.
I assume that if energy from coils is extracted in some manner (pulsed or constant) that this extraction will
make self rotate rotor. if not that it will at least make rotor to turn easier from the outside.
eather way this is FE generator.
Can you please make some sims with fem or some "stronger" program to confirm or discard stated above.
Perihelion Labs
Igor Knitel
gyulasun
Hi Igor,
Seems very good, now it is high time to test it practice for sure.
Gyula
wizkycho
Hi all !
http://www.youtube.com/watch?v=JRNZSu31ZZo
proof of concept. Magnet Transistor Exists.
Unlike Common tranzistors it uses INFINITE source of magnetic field - permanent magnet
Wiz
wizkycho
Hi all !
to procede experimenting, can someone buy and send me 3 pieces of A1302
(http://www.allegromicro.com/en/Products/Part_Numbers/1301/1301.pdf)
(I requested sample parts, but there is no answer)
I'll pay You the cost of parts, postage and packing plus the effort, cause I can not find this or simmilar part
in electronic stores near me.
THX
Wiz
