1850 Watts free energy power ? New GEGENE circuit by JL Naudin shows COP = 2.8
Started by hartiberlin, December 29, 2012, 08:16:11 PM
picowatt
His new numbers, attained via confirmation of lamp output with a light meter, are a more reasonable 92% efficiency or so, which is still pretty good, but not OU.
Quote from: wings on December 30, 2012, 06:32:58 PM
High Frequency Domestic  Induction Cooker - circuit
http://inpressco.com/wp-content/uploads/2012/02/Paper5126-132.pdf
Good paper, thanks for finding it. The envelope-modulated sinusoidal waveforms shown in the paper are similar to those shown by Tagor above. From the paper, I think I am understanding that the envelope modulation controls the depth of penetration of the heating effect into the pan, while the basic, higher frequency oscillation is what is transferring the power.
Here are some variants on a simple Zero-Voltage Switching self-resonating oscillator which can be used as a wireless power transmitter, a flyback driver, or an induction heater, depending on the frequency and the geometry of the output coil, and the power supply.
I use variants of this basic circuit for my wireless power systems and my flyback Jacob's Ladder.
By lowering the frequency by making the output coil bigger, say 30+30 turns, Litz wire, flat, and using a power supply and mosfets that will deliver more power to the coil, you can have your basic induction frying pan heater.
Lower the frequency with big capacitors and you can have the classic induction furnace, with a few loops of copper tubing for the output which wraps around your metal object to be heated. Again, mosfets and power supplies must be up to the task. Generally the mosfets stay pretty cool if the circuit is working properly.
It's the same basic circuit, though, in each case.
In the versions below, the cross-over diodes can be any robust, fast diode; the zeners can be 12 or even 15 v; the 1000uHy choke value can be varied quite a bit; the mosfets I use for ~800 kHz wireless power (single turn air-core output loop) are IRFZ44n and for lower-frequency flyback driver (5+5 primary on ferrite yoke)  IRFP260; for induction heating (larger spiral coil) IRFP460 on good heatsinks. The capacitors must be poly film type and over-rated for voltage; use high quality caps. Do not attempt to operate without the load, you will blow mosfets instantly.
With tight coupling, bifilar coils of Litz wire, and IGBTs or very low Rdss mosfets in the commercial induction heater circuit I would expect the power transfer efficiency to be quite good (but not greater than unity).
These circuits do not produce the envelope modulation of the commercial cookers, though.
A neat thing for Jean-Louis to try would be to put a second load coil and light bank on top of the first receiver coil.
FatBird
Why not add another Bifilar Coil on top, so there are TWO of them.
It seems logical that some of the radiation is sneaking past the coil
in the picture, so why not capture it with a SECOND Coil?
Even if the second coil only got another 20%, it's better than nothing.
