1850 Watts free energy power ? New GEGENE circuit by JL Naudin shows COP = 2.8
Started by hartiberlin, December 29, 2012, 08:16:11 PM
SchubertReijiMaigo
Why they are not using that !?
http://www.clarke-hess.com/2330.html
Nothing beat mathematical integration to have high precision measurement...
Scope are great too if they are equipped with math integration function.
Hmm,
Naudin just posted an update:
http://jnaudin.free.fr/gegene/gegene05en.htm
and
https://www.youtube.com/watch?v=Iik6XnT2mE4
Seems he only gets now 91.4 % efficiency
when measuring the light intensity...
He says that he wants to do more tests.
I really would lke to see some scope shots of the involved waveforms from this.
Many thanks.
Regards, Stefan.
e2matrix
Quote from: Eighthman on December 29, 2012, 10:21:25 PM
I really, really hope people will STOP trying to measure output using lightbulbs.  Get some diodes, build a good filter and connect it into a simple resistive load, with meters.  Not hard to build, not expensive.
Making lightbulbs glow and then claiming output - even if you measure the lumens/candlepower/whatever - isn't good because high frequencies can create nice glowing plasma ( as Tesla discovered long ago) apart from a hot filament.
Still hopeful,
Eighthman
Did you see he also showed AC voltage and current output?  I know that may not be the most accurate way but could it be that far off?   Isn't the induction heater a resistive load?   If so would it be possible to loop this?   The electronics in the induction heater might not like it but you could probably bypass them and just hook straight to the induction coil.  Or make your own.   Give it a jump start from the grid and have a relay flip it over to loop it?   Sounds easy enough to try.   Wouldn't that be a hoot if that's all it took....
e2matrix
Quote from: hartiberlin on December 30, 2012, 01:05:12 PM
Hmm,
and
Many thanks.
Regards, Stefan.
I know the induction heaters use a board full of electronics.  I wonder how much efficiency is lost there?   It seems it might be better to wind your own induction coil BIFILAR and skip the electronics and just use the Variac.  Measure output from the Variac to the input of the bifilar induction coil and I'll bet it gets much higher efficiency.   Since I've got a big Variac I may give this a try soon.
SchubertReijiMaigo
A simple power In vs power Out with true RMS wattmeter or scope with math integration will do the job no matter current/voltage waveform...
Second: how on earth a loosely coupled air core transformer will get Cop > 1 ? Until it come to play resonance/quarter wave effect or some weird effect.
91 % efficiency is pretty good for an air core trafo !
