Free Solid State/mechanical energy
Started by KSW, April 13, 2005, 06:59:25 PM
0 Members and 17 Guests are viewing this topic.
Grumpy
Erfinder,
Hell, I'll build it.
Where is the primary coil located?  The drawing does not indicate how the primary is wound.
Also, is there a ferrous core or just a core form (such as wood or palstic)?
Does closed magnetic loop core rotate?
        -Frank Edwards
orosado
Quote from: Grumpy on February 16, 2007, 12:33:03 PM
Erfinder,
I'll make a wild guess about the primary coil location. See the attached picture.
Also regarding the magnetic ring, I guess it is composed of four segments, each segment having a Postive and Negative side. Each segment forms a ring, but there is a gap  where the segments meet.
orosado
It seems to me that this device is a motor and generator at the same time. The magnetic ring is placed on a rotor and the rotary switch is placed on the rotor to switch polarity on the primary coil. The secondary coild could capture radiant energy at certain intervals, which is fed to the primary coils. Of course I could be assuming incorrectly...
Grumpy
I agree witht he primary location - didn't notice them before.
How many positions on the rotary switch?  This looks like a comutator, so it would rotate with the "rotor".
I assume that the closed magnetic ring rotates, or is it fixed and just the comutator rotates?
Any recommendation for the coil windings?  number of windings, wire size, etc.
Would think that core is non-ferrous for this application.  Is this correct?
This arrangement, asuming it works, will jack with the vector potentials and cause a momentum violation - aka lift.
        -Frank Edwards
barbosi
I agree with ResinRat2, I see Stefan made just a joke, knowing there is nothing to make you change your decision.
As you said...
Quote from: Erfinder on February 13, 2007, 01:19:25 PM
P.S.
I will not make photos, ever, so hate me or hate me.  I am sorry, but nothing anyone says will change this.  If this is not acceptable then I will leave, this is not a problem, I am here to inspire, not to change the world.  The proof you require is within your grasp.  Study, and build!
... he chose the only option you offered.
Anyway, back to the subject, the only problems I have are:
1. The switch configuration (there are 4 wires going into the switch and I cannot see clearly which one going where to make sense as a timing device)
2. Please give more directions for further lecture concerning vedic measures. There is a major difference berween the terms we use nowadays, compared with those in the far past. An example beside the "inch" concept, there is also this "octave" term. As you know, "octave" is a matter of multiplying a frecquncy (note) by 2.
From your previous example, there is a factor of 3 (like a third harmonic).
I would sugest to adopt a comon language, so all interested in the concept willing to debate on this mater, will be on the same page.
Although I'd prefer you leading this initiation, I cannot abuse your time, so if you please, give us some directions (links, documents, pictures, etc). This way, I believe more people will come in contact with the principles you are trying to put in our sight.
Thanks.
When the Power of Love overcomes the Love of Power, there will be peace.
