Free Solid State/mechanical energy
Started by KSW, April 13, 2005, 06:59:25 PM
nat1971a
barbosi
Maximumgravity1,
I admire your determination. I'm so glad you accepted the challenge. Many of us for diferent reasons cannot do what you are up to. Please keep us up to date with your results and no matter the results, I'm sure you'll be assaulted with questions. Please be prepared to post pictures and video clips.
Thanks for your efforts.
When the Power of Love overcomes the Love of Power, there will be peace.
turbosetch
Erfinder,
            I want nothing more then to understand the lesson. I am still lost in what your trying to teach. The numbers mean some thing as I see them with Ed's work and many others yet I seem to not be able to make the connection. Would it be fair to say that myself anyway am not able to grasp the concept?
I will go back again and read all you have posted and make further notes. The riddles here are perplexing to me. I for one am not looking to be spoon fed but perhaps you could simplify things for the simple minded.
I want to understand my heart is in the right place but frustraition is what I am fighting right now.
I guess I will fade back until I one day understand the meaning of this all.
Thank you for what you are trying to do, I appreciate it.
scotty1
Hello all....This is Scotty from Leedskalnin.com...I felt my ears twitchin' so i thought i'd drop in....If anyone would like to know about the pmh, i would be glad to answer...as i have done at OU.com before.
I also have a full spectro analysis that i had done on the coral from Ed's castle posted on my site...I too was curious so Matt Emery sent me some...It was tested at my workplace (a steel foundry) where we have a spectro lab.
I have also had the a pmh tested with a gauss meter quite extensively and will be posting pics on my yahoo group soon...
The point with the pmh by Ed himself is that there is a small current circulating in the metal...The circulating current causes the same effect on a small needle as the current in a copper wire does.
The pmh obeys the right hand rule of electricity, except that Ed says that the South pole individual magnets run from the south pole prong to the north pole prong, and the North pole individual magnets run from the north pole prong to the south pole prong.
Each knid of magnet particle run in a right hand twist against each other.
When these particles are in a battery, they have the want to push away from their own terminal because many of the same pole are near each other. When the connections are made, these magnets obtain pulling power because they are attracted to the opposite kind.
A current carrying wire does not have concentric circles of magnetism surrounding it.
If a foot long copper wire is placed in an E/W position, connecting East to batt pos and West end of wire to batt neg, (put batt south of wire) then the whole length of the North side of the wire is a North pole and the whole length of the wire is a South pole on the south side.
The reason for this is the centrifugal force that throws the magnets out of their right hand twisting path as they interact with the copper atoms and the other kind of magnet running against them.
Lenz's law is caused by the North and South pole individual magnets running in a right hand twist.
There are always excess magnets in any wire that come from the Earth's field, but they are not facing the right way and so will not run..They point accross the wire.
When the battery is connected the magnets build up and any excess magnets in the wire are forced TO TURN ON THEIR AXIS.
It is well known that you have to move a coil through a field to get power, and the sine wave shows how the magnets build up to a maximum for that particular field, wire and coil size ect. When the polarity reverses it shows that the individual N and S pole magnets have flipped on their axis and now run the other way, which is demonstrated in Ed's notes.
Now when you use a square wave into a coil the situation is different. In this case the magnets are dumped into the wire all at once and are running in a slanted fashion and the centrifugal force is greater...then the current goes off while at maximum, and all the magnets that are in the wire, which at that moment is overloaded with them, try to turn on their axis to face accross the wire as they do when there is no pressure in it...the problem is that there are too many magnets in the wire, and as each magnet turns it wants to seperate from any of the same polarity.
When the magnets were running in the wire they were running head on, but now they try to position themselves tail to tail pointing accross the wire. Because there is too many of them in the wire when the current is switched off at max value they create a large outward burst from the coil in a radiant manner....it is like trying to line up bar magnets very close together with all the north poles one end and the south poles the other end....they will want to spread out....some of the magnets flip so fast that they start to run in the opposite direction...back emf and the higher voltages obtained demonstrate this...so did Tesla.
It all happens in a tiny fraction of a second, probably better if i drew it all up..
Now it's late and i gotta go beddy bye...
Best wishes
Scotty
orosado
Quote from: Erfinder on April 10, 2007, 02:49:17 AM
Your negative comments don't effect me.  It is ignorance which makes us say some of the things that we say!  Ignorance of nature's ways, nature's laws!  You all would test me, and as usual in these situations I give you yet another gift!
Think for yourselves!  Don't listen to them when they say you must experiment!  Nature doesn't experiment, if she did your lives would be a living hell!!!
Spoon feeding is not my thing!  If just 10 of you could begin to comprehend the insights I have brought to this thread, this discussion would go around the world overnight, this would attract others who are further along in their development.
Hello Erfinder,
As always, thank you for your patience with us. I know that you have shared a lot, knowledge that take years to acquire. For that I am grateful.
Don't be discouraged by those of the negative kind, they are just on the wrong path. They are only filled with fear. Fear is the only thing that keeps us down. We all need to gather courage. With courage anything is possible.
Please know that if some of us we stay silent a while it is because we are digesting the information and insights you have shared. I believe that those of us that have a positive attitude are doing our best to comprehend your teachings.
Omar
