Free Solid State/mechanical energy
Started by KSW, April 13, 2005, 06:59:25 PM
barbosi
Erfinder,
I think we need a Roseta Stone. Ponder about this and if you find it right you may add it to menu in your website).
You mention "quality" in couple occasions and I'm not sure how to take that:
In your post http://www.overunity.com/index.php/topic,133.msg27159.html#msg27159 you say:
"... A stone ground into a fine powder mixed with a binding agent, and then sun dried makes a perfect new age surf board.  You only require the proper quality magnetic fields to ride on!  No power supply just magnets and coils! ..."
Then later in http://www.freewebs.com/walter-russell-effect/anyandeverything.htm you state:
"Electricity = Light, Sound = Light
These two represent different qualities of Light.  Quality!  There is something new!"
It seems "quality" is regarded as two different interpretation:
1. achievement or excellence
2. a characteristic
Can you explain?
When the Power of Love overcomes the Love of Power, there will be peace.
orosado
Quote from: barbosi on April 18, 2007, 09:15:36 AM
Erfinder,
2. a characteristic
Can you explain?
Hello Barbosi,
It seems to me when Erfinder mentions quality, it is in the definition of "a charaterictic".
Erfinder correct me if I am wrong.
Omar
orosado
Hello to all,
Erfinder once told me that a coil can act as a capacitor. I guess a proper quality coil would act as a capacitor. In this quality would refer to winding scheme, like a Mobius or Rodin coil.
Omar
bocas
Orosado,
    I recall that when a coil has a negative inductance in a circuit, it has the same phase as a capacitor....Jeff
Charlie_V
A coil can act like a capacitor if the inductance is large enough.  Current doesn't change instantly, a voltage across the coil is usually produced first, and the voltage dies down as current starts flowing through the coil.  So, if you had a proper arrangement, then the voltage decay across the coil could be slow enough to make a capacitor like effect.
The same can be said for a capacitor.  Yes, capacitors have inductance.  This is because voltage cannot change instantly.  The plates of a capacitor cannot instantly be charged.  So at first, the current is very large and begins to decay (as the capacitor is charging).  During the initial time frame, there is a magnetic field spatially 90 degrees from the capacitors electric field.
This effect is how antennas work.  If you can tune things such that the magnetic and electric fields are in phase time wise (not spatially because the magnetic and electric fields are always physically 90 degrees apart with space), then you will produce radiation (aka radio waves).
For some reason, they never explain things well in science books.  It took me a long time of thinking before I could visualize this.
Hope that helps,
Charlie
