Free Solid State/mechanical energy
Started by KSW, April 13, 2005, 06:59:25 PM
zepharim
here is the patent on the coil to replace the capacitor and to neutralize the inductance in an ac motor for commercial efficiency purposes - forgive my dry loose terminology on this topic ...read this one and be amazed... their is a neat clue in this little one! - hmm set up differently in the AC motor we are studying ... isnt it ... theres even a capacitor?
eg: Telsa states that this coil setup neutralizes the inductance, as the AC "operates  disadvantageous by giving rise to false current which often reduces, what is known as, commercial efficiency of the aparatus composing the system ... i see what he saying ... cool eh dudes!?!!!
Man i love this stuff... yeee hoooo!!!
orosado
Quote from: zepharim on April 18, 2007, 01:35:47 PM
Hello zepharim,
According to Wikipedia, that is the patent in which Tesla introduced the Bifilar coil. Apparently having two conductors in the coil neutralizes induction because the magnetic field around both conductors is the same.
Omar
zepharim
Hi ERFinder,
I wish i was not so condiluted ... but in time ... thanks be to your patience.
Lines 26-31 Patent - 512.340
It can be seen in my last post regarding the coil patent - Telsa stated that his coil windings will achieve the same effect as the cap thus eliminating the need for the caps - but also suggests that the induction is neutralized also - I see that the relationship between capacitance and inductance (forgive the mainstream) are relative. anyway thats another topic.
OK lets get this show on the road:
The Electro magnetic motor patent 464.666 -
To put it simply, I see that Telsa is transfering electricity from one place (in this case a circuit) to another place (in this case another seperate circuit) via a wireless medium (in this case the electro magnetic field - telsa coils).
This is what i get out of it thus far ... as for the 6 energizing coils being capacitors .. i didnt quite look at it that way - it is with much shame to have to admit its not totally my own yet .. :-(
In short, this is truely the beginning of wireless technology - wirless power!
Transfer/Replication of energy across distances via a wireless medium such as a magnetic field - via capacitance?!!?
If anyone is making the same mistake i am and not sleeping enough ... start getting sleep ... more has sunk in by taking it in stride (and alot faster than when i dont sleep) i am a techno junky now ... i think im gonna have to start an TA clinic (Telsa's Anonomous)  ...;-D
Alright gang, what do you see!?
Sincerely,
z
satyoda
Hi to all,
The way I read the patent
1 this is not a induction motor (read carefully line 15 to  20)
2 the primary an secondary coils are acting as a capacitor and their for must have an equal weight.(See line 21 to 24)
3 the value of the capacitor H must stand in relation to the value of the coil capacitor (See line 55 to 58) in order to get a 90 degrees shift see line 43 to 44 an also 60 to 61
4 the drawing in a non working model but only an explanation see line 62 and 63 and 68 to72
5 the drawing is showing that the coils should be wound close together (some where else I read isolated from each other with wood) here is our capacitor (see line see line 66 to 68)
6 the alternating current mention in the patent is a switching DC power (see line 103-104)
7 This is only one field it would take more of these setups to make a working motor, generator See page 2 line 13 till the end( we also have seen this in the 3D drawing from erfinder.)
Tesla is talking about induction in this system sins at that time there was no word for what was happening But it is NOT induction as we know
If a coil is induced by a sort current the resistance will build up enormously an their wil be no flow of the current in the coil wire  and their for the hole system is not consuming power from the power source.
This is creating a void  sins everything must be in harmony the coils acting as a capacitor will be charged from the electrostatic
I am assuming that the magnets are used to multiply the frequency of the power source by acting of the voids from the coils and the magnets.
only Erfinder or Tesla could confirm these
I am looking forward to his answer
regards,
Hello Erfinder,
Dr. Pavel Imris uses in his publications "Bandkondensator" as (primary) coil,
Condensator=capacitor, with the effect : "Blindstrom" to "Wirkstrom" !
He also describes the different behaviour between inductance and capacitance !
About wireless "tele"-communication:
Antonio Meucci
S
 dL
p.s.: hypothese: actio= centrifugal force-field (expansion)then reactio will be a =
       centipetal force field(compression) or vice-versa
