A Kapanadze generator replication - Febuary 2013
Started by tika, February 20, 2013, 03:55:50 AM
tika
@totoalas
I still don't understand why you need such a high voltage.   You may fry your coil.
m:o)
totoalas
Hi Tika
Im trying to use as little input(12 v dc from solar )  to the primary coil as possible as I want to use solar as source  for hybrid kapanadze
The flyback as a cheap alternative  to the  kapanadze tech that can have same or near results will simplify the construction from off the shelf parts
Guruji has light on even in a flicker is a good sign of things to come
In Per Linderman Plasma  mod of AAron Murakami  the spark gap plasma has great impact on cars.....   and if we can apply same technique  will be better   battery   earth   plasma   coil   ?KW load
As you said the control of the plasma is what is needed to convert to useful energy  thats what im after for.......
ihave the parts for the 555 timer   relay caps and coils in an e core   ....  well see where it will lead me   at least Romerouk had initially tested gyulas circuit and saw an increas in cap charge .....then guruji lighting a lamp in a flicker fasion.....  then maybe more to do this set up
Im for kapanadze but if theres another way to achieve this will be better   more choice for the third world countries to benefit
please try this also as it has simple parts and let me know your opinion ...... thanks\
totoalas :)
totoalas
Quote from: tika on March 05, 2013, 05:44:05 PM
@totoalas
m:o)
From this simple experiment IMO, two facts have emereged. First you need a strong healthy spark. And I noticed while the Spark Gap was running I could hear the underlying 50 HZ base frequency but as this was going on, audible fizzing of the SG saw the light intensity increase with the fizz. So even though you rectify your HV AC the underlying drive frequency is carried through. So IMO a High frequency voltage supply is also a must.
quote from grumage
zcsaba77
Quote from: guruji on March 05, 2013, 02:19:45 PM
Hi I'm using a ZVS as driver. SG should be very close. Beware  not to explode the cap  :o
Today I tried alot of setups but still wondering which is the best.
I think cap should be in parallel though with flybacks like all Tesla coils.
Ok I should see more on this.
hi guruji
if u left too far spark gaps catodes, cap(s) explode? this coil is air or ferrite cored? how u calc how much turns need forward and back?
tika
@totoalas
Your guess is as good as mine at this point.  Yes, high frequency is probably important to get the maximum energy gain.  But, as zcsaba77 pointed out, too high a voltage will fry your caps, it will also create arcing conditions in the coil itself and may burn your construction.  Just be careful, OK?
I am going with the theory that scalar waves are transferring energy, the electrons are pumped from the ground wire going through the coil by the the same effect discovered by Sergey Zatsarinin.
http://jnaudin.free.fr/dlenz/DLE01en.htm
http://www.meyl.eu/go/index.php?dir=60_Documents&page=1&sublevel=0
@Grumage
High permeability is good for the kHz frequencies you are generating.  Iron is not fast enough to charge up with magnetic energy at high frequency.  ยต=7000 should be a good range for 25-40 kHz.
I video #4, Wesley states that the caps on the output side were needed to store output power to keep from flickering, and also that the device did not work well without an output diode.  Diode may not be needed, as your coil is totally different.
I wish you both success.  We will all be able to compare results soon.  Cool!
m:o)
