Something interesting I found, about diamagnetic material. Might prove usefull
Started by ace569er, February 23, 2013, 03:48:23 PM
ace569er
Something interesting I found, about diamagnetic material.  Might prove usefull to someone...
Subject: Bismuth/Pyrolytic Carbon foil Laminates, Diamagnetics.    onthecutting...
Hello.
I'm a researcher who would like to inquire about very thin foil sheets of Bismuth.
The Bismuth sheets must be less than 1/128th of an inch.
The second Material to Inquire is less than 1/128th of an inch of Pyrolytic Carbon foil sheets.
If these two materials are in stock I would like to receive information of volume and pricing.
These materials are for special research in Bismuth/Pyrolytic Carbon laminates for the use in Highly Diamagetic field studies. These two materials when Laminated in multi layers achieve above normally high Diamagnetic material at room temperature normally only seen in Superconductors. Although the Superconductivity is not presently seen in this material the Diamagnetic fields are exceptional when all the Pyrolytic Carbon sheets are oriented unidirectional as a laminate with the Bismuth sheets.
Research.
Gerald L.Blakley
TechStuf
“For the wisdom of this world is foolishness before God. For it is written, “He is THE ONE WHO CATCHES THE WISE IN THEIR CRAFTINESS” - 1 Corinthians 3:19
http://www.freemasonrywatch.org/sixpointedstar.html
http://www.youtube.com/watch?v=XBjOs-egFMs
http://www.youtube.com/watch?v=_WSGwnz7XpY
http://www.youtube.com/watch?v=l39XsMcyvgA
http://portland.indymedia.org/en/2004/09/297062.shtml
http://www.youtube.com/watch?v=JjjIy1DO0gs
We all have the choice to waste ourselves in rebellion or to gain wisdom.  Therefore, gain wisdom:
http://www.hisremnant.org/eby/articles/kingdom/twohands/twohandsof.html
ace569er
Thank you, not sure if I personaly want them, but thanks. I'm sure someone does.
Gwandau
Quote from: ace569er on February 24, 2013, 07:31:49 PM
ace569er,
I obviously failed to distinguish your own message from the quote you added,
but as you politely indicate, there may be someone interested in the information anyway.
An interesting fact is that Bismuth becomes a semiconductor when deposited in sufficiently thin layers on a substrate,
and will reach anomalously high resistivity peaks at certain electromagnetic frequencies, unlike any other known metal.
Gwandau
