Gravity engine
Started by Gabriele, May 02, 2013, 02:44:51 PM
Gabriele
I find interesting the behavior of this apparathus ideated from myself.
The resultant of the forces on circumference of 2 liquids are perpendicular to the base. We have also a torque on the vertical wall.
If we fix the base to the center of a force of gravity,this should rotate,right?
conradelektro
This will be the end of it.
Greetings, Conrad
Gabriele
You have pointed the center in center of ball. This isn't what i ment. You have to fix the ball on the base. With a long tube reach the center of the earth. So this ball should rotate right cause momentums.
conradelektro
Quote from: Gabriele on May 02, 2013, 03:07:33 PM
I do not understand what you mean. But it does not matter, because nobody can build a tube that reaches to the centre of the earth.
Never mind, Conrad
Gabriele
Should appen this
__________________
I know this is impossible to build,but it seems go counter 1law of thermodinamics,from my point of view
