Big try at gravity wheel
Started by nfeijo, May 03, 2013, 10:03:04 AM
Red_Sunset
Quote from: Poit on January 01, 2014, 03:53:35 AM
IS THERE SUCH INSTRUCTIONS ??? NO!!! SO SHUT THE FUCK UP UNTIL YOU DO!
"I can state categorically that you were definitively not talking on my behalf." so you have these instructions then? enough talk, post it! let me make it clear to you that you are saying to me that you have detailed instructions on building an over unity device...... because if you do not then you "categorically" ARE included in the 7+ billion people comment idiot!
"I do realize that this forum cannot be a 1 to 1 classroom to explain everything from a-z" do you realize that you don't need to technically understand something to build it? in the joule thief example, do I need to understand how transistor functions in order to build a joule thief? NO!! so what gives? your an idiot!
"Sure we all WANT,  a solution answer to all our questions with blueprints to build our fabulous home OU power generator, tested & proven before we begin building.  Be aware that there are many steps in between, many wrong paths and turns." The point is that Grimer and others claim to have these blueprints, and it clearly bull shit! i'll eat my words if Grimers next post is these elusive blueprints he talks of!
If he and others do NOT have blueprints.. state it now and i'll shut up..
No further comments   (only disappointed)
Poit
What you want is fine.. but thats not what Grimer has said.
Who am I to judge people wanting to figure something out? thats cool.. but to claim you have proof is an entirely different matter!
you want 2014 to be a good year? lets ALL start by telling the truth?!
Something along the lines of "Hi everyone, my name is Grimer and I have previously said I have proof of over unity, I lied."
seriously. you reckon he will say that? or anything close!
no.. you want peace, fine, you and I can be peaceful, but gloves are off to Grimer and the likes that just sprout bull shit
Grimer
Quote from: Red_Sunset on January 01, 2014, 04:20:17 AM
Hi Grimer, a Happy New Year,
I didn't analyze in detail the RAR weight manipulation since I do not consider it directly part of the main principle (I assume).  Although the weights do play a major function in the mechanism in order to do "cost saving" and therewith increase the output.
The working forces are centered on the central shaft for gravity weight (roberval) and as a pivot for weight leverage. For the latter, the positioning of the weight 'center of gravity' becomes very important.
From my superficial view, the inboard weight is the main working weight (the reason for it to be most of the time in movement) and the outboard weights are counter balancing the inboard weights at certain times.  At predetermined positions, their counter balance is terminated by allowing then to rest on a ground support (angle dependency, the reason why they are not always in motion).
I can not see the RAR weight arrangement as a pendulum oscillation since it is far from free moving being constrained and controlled by locks to synchronize its movement to support the main lever mechanism.
Red_Sunset
Hi Red Sunset - and a Happy and Peaceful New year to you, sir.
QuoteFrom my superficial view, the inboard weight is the main working weight
I agree
QuoteAt predetermined positions, their counter balance is terminated by allowing then to rest on a ground support
I agree. Moreover I consider this ground support to be essential in getting Newtonian Gravity to act asymmetrically.
It is interesting to note that the end elevation diagram does not show the outboard weights reaching the ground. I wonder if RAR even realise this is an essential feature and why it is essential. Perhaps they don't understand the nature of the grounding. Perhaps they don't perceive that it leads to the partitioning of jerk energy and allows one half to go to ground and the other half to drive the crank thus conserving angular momentum.
Alternatively, are they trying to mislead with that diagram to keep their discovery secret a little longer?
Who is she that cometh forth as the morning rising  -  Fair as the moon. Bright as the sun  -  Terrible as an army set in battle array.
minnie
What we need is someone like Michel Henkens to write a detailed explanation similar
to that done for Hydro Energy Revolution, then we'd all understand.
              John.
Red_Sunset
Quote from: Grimer on January 01, 2014, 07:52:17 AM
It is interesting to note that the end elevation diagram does not show the outboard weights reaching the ground. I wonder if RAR even realise ...................................................................................
Hi Grimer,
There is no good picture to give you a view, where these counter weights are parked on the ground.
But I do think there is a high probability that they reach the ground at some point in the cycle for the following reason,
1.. The weights have feet to to account for a gap existing with the floor
2.. The weights are mounted on a shaft allowing for positional rotation.
3.. The weights are mounted on a 180dgr hinge (this allows the inboard weight to increase height without impediment)
3.. The advantage to disengage the counter weight when the inboard weight is at its highest to achieve highest gravity force
See the 2 enlarged pictures attached
Red_Sunset
