Finally! Independent Testing Of Rossi's E-Cat Cold Fusion Device. Success?
Started by rukiddingme, May 21, 2013, 12:06:50 AM
FatBird
OscarMeyer
all the guy has to do is show accurate electrical input by placin the right test equipment and data recorders in series with the wall socket or main disconnect/breaker and the device.  Then we would have the total overall input power going in at all times including when the power input is reduced in the so called selfrun mode.  that is the first thing
then the output is going to be heat so you use the hot-cat to heat water and in an isolated water circuit.  using a heat exchanger you just use a second isolated water circuit which will safely cool the primary water circuit and you measure the second water circuit temp before and after it goes thru the heat exchanger with calibrated "K" thermocouple and multi-channel professional chart recorder.  afetr the it goes through the heat exchanger it will need to go thru a cooling tower and possibly a chiller so the water doesn't get too hot being recycled because the test should run for at least 3 weeks straight.
take your flow rates and heat measurements and then convert heat to kW thru known formulas and you have a conservative result.  everyone knows ALL heat exchangers are very INEFFICIENT so the result will always be lower than it really should be but if the hot-cat does half of what Ross says it does then it should have no problem showing higher output than input.
OM
But it doesn't, because it can't, and he knows it, so he won't.
OscarMeyer
exactly. if any university really believed the results recorded in the latest round of testing, they would buy one of Ross' units and run monthlong testing of the unit because then ross could not interfere with any of the test parameters including the length of the test. after all this would be the single most important discovery in the last century so it would be a no-brainer to get the large unit that supposedly got sold to customers who are not proud of their product from ross and won't talk about it at all.   but the universities are not buying any of this and neither am I.
OM
FatBird
Rossi's Free Energy invention is causing HITLER to PANIC.  Click on the link below to see it:  LOL
THIS IS A MASTERPIECE!!!
http://www.youtube.com/watch?v=uX0vcU4iedQ
