Magnet coil cores, demagnetization power and Lenz delay.
Started by synchro1, June 09, 2013, 11:07:49 AM
MarkE
Quote from: synchro1 on December 05, 2014, 03:11:51 PM
I'm through spoon feeding you. All you've done is cause trouble. Everyone's already seen all that old stuff already.
LOL, well if you can point to a post that actually had a drawing or picture of the thing that you are asking about then I will happily apologize.  If you can't then you are just being silly.
synchro1
MarkE,
Just stay off my back and stop causing trouble.
MarkE
Quote from: synchro1 on December 05, 2014, 05:40:59 PM
MarkE,
I must say that you are acting very strangely.  First you ask for an evaluation of some thing then when I ask you to show the thing you want evaluated you act very upset and put-out.
synchro1
I believe this TK circuit may work well as an automatic "Neutral Zone" positioner with a magnet viewer to trigger the optical sensors, coupled with the motorized ultra magnetic positioner pictured above: The "Neutral Zone" is non-magnetic and would reveal itself as a black line through the magnet viewer.
https://www.youtube.com/watch?v=SUsA-YuAtBU&list=UUZFlznLV3IyePfbc2TfDetA
synchro1
Doug Konzen demonstrates rotor acceleration and decreased input by positioning a shorted magnet backed ferrite core coil in adjacency to a monopole rotor in polarity opposition to the core magnets. This magnet backed coil and monopole rotor polarity configuration is identical to kEhYo's GAP setup. Let's say we wire a blade switch to the output side that shorts the GAP power coil after thr DPDT relay is pulled. Inescapable logic dictates that when the coil's re-positioned as Doug shows, the rotor has to speed up from forces in the shorted coil alone, even though input has been completely curtailed! Think about what I'm saying! Videos can easily be faked. The logic I'm using is irefutable! This test is simple enough for anyone to perform. You have my solemn affidavit that free energy is this simply achieved! The only stipulation is that the rotor be as close to frictionless as physically posible. A VCR bearing with well balanced magnets like Skycollection uses will work fine.
The rotor continues to speed up with zero input and the shorted coil needs to be constantly re-positioned to a new sweet spot. This can get scary and requires a bit of courage. Prepare yourself for "Future Shock". The psychological effects of self acceleration are potentially traumatic!
