Rosemary Ainslie Circuit Demonstration June 29, 2013 Video Segments
Started by TinselKoala, July 01, 2013, 08:17:22 AM
SO there you have it, sports fans, once again. The Q2 current path, the oscillations, the negative bias supply and the spurious nature of the current values derived from the oscillations on the shunt are fully explained, as is the mendacity of putting the Black FG lead where they do, allowing the current path through the FG to bypass the CVR and not show up in its readings at all.
Ainslie has no excuse whatsoever for her continuing fantasy that there is no return path for the current during Q2 oscillations, she has no excuse whatsoever for failing to understand that fluctuations around 4 volts on a mosfet gate will cause substantial conduction, and she has no excuse for badgering .99 with ridiculous strawman arguments about gates passing this or that or whatever.
But of course she will persist anyway.
markdansie
You mean, "So shut up already!" of course.   ;)
But I haven't put the circuit back together with the other transistor yet, to show how that behaves!
:P
Meanwhile, I see that today, over ten days after the demonstration, .99 is asking for the Donovan Martin team's screenshots to be released, and that Ainslie persists in her delusions about how the circuit functions. It really is too bad that she is too arrogant to watch my simple explanations and discuss them like a rational adult scientist might.
markdansie
@TK
did you expect anything else. I will follow up on the screen shots.
OK have a question
We have another self looped battery generator her in the Philippines. I would like your 10 cents worth on how you think I should test it.
I need not state my public opinion on thisi t is well noted
Kind Regards
Mark
@ Mark: Sneak past the claimant's home and see if they are still hooked up to the utility grid.
Just kidding. Sort of.
Of course without knowing the specifics of the device, which you probably can't tell me, I can't suggest a test protocol for it.
