Agha Waqar running Car on his HHO Fuel Cell
Started by Paki1, July 14, 2013, 10:26:30 AM
profitis
give me a high-5 @kator.we just proved that water was split at 0,5volts and the back-emf that formed from the surface area coverage of h2 and o2 caused increased resistance to current flow.if you had detached and measured after the 0.5v run you wouldv seen voltage and current coming out of the fuel cell.try using 2 kitchen steel knives  now @kator,its dificult to see bubbles on the carbon due to clinging adsorption.
profitis
i think if we use steel knives in caustic soda the recombination and detatchment of atomic h2 and o2 should happen faster.make sure that the knives are degreased,washed properly @kator.
Kator01
profitis,
yes I will do so and repeat the experiment at the 0.5-Level.
True, tiny air-bubbles are attached even without the power on. I have to let the rods rest for an hour and than clean them of the bubbles. The coal is porous and I would suspect that a voltage was there at the very beginning. i.e before I first switched on the power.
Too early this morning..will go to sleep..
Kator01
profitis
aha kator.porousity can be a friend and villain at same time when it comes to carbons.i agree,we must remember that any air in the hydrogen electrode has to discharge first electrolyticly before h2 begins to form,but no problem as that happens in seconds.we just pass current 4 a while,detach,measure fast,bingbading.rest well mate,l8ta
markdansie
Quote from: profitis on August 20, 2013, 01:52:30 PM
@markdansie,,ive done dozens of experiments mate..some with frightening results.if we understand the late great walther nernst,the text-book favorite on electrochemistry we can manipulate voltages.
And no data or hypothesis put up for peer review so how do you knwo what you are looking at?
Mark
