pedal power
Started by Dr, August 03, 2013, 05:26:24 PM
Dr
Ah much better!! I will repost the stator.
Dr
I progress: today I tried to put my homebrew altenator together, without using the jacking screws, thought I would save some time. BIG mistake if it hadnt been four 1/2 inch bolts on the back rotor assembly I would have crushed 8 fingers! :-[  24 neo s at 52 lbs pull each, ouch! I left it alone for now and made a rectifier of sorts, with heat sink
Dr
Hello again: dont know if anyone is interested or not but I worked on my pedal power dynamo again , the last two days I have been working on a frame of sorts, it will hold my batteries, altenator and flywheel. here is another picture.
Dr
Imade some more progress on my pedal power machine today, I pretty much put all the parts together( except a seat) and did a few tests to see what kind of out put I was getting from the altenator. I was able to light a 12V car headlight,  A 12V dc motor ( from a cordless drill) and slightly charge a 12V battery all at the same time. If I keep the flywheel at about 60 RPM , I get about 15.7 Volts. I am having trouble measuring the amps, and I need some help to see if I am hooking up my meter properly? anyway here are some more pics ;D
Dr
was trying to do more than one pic. :-[
