New Perm Mag Engine Design 1.5 : 1 Ratio (work from magnets)
Started by Floor, August 05, 2013, 08:36:48 AM
Floor
I still hope for peer review.
Has anyone done or is anyone planning to do error checking on my paper work, or is anyone building their own version of a"TD" test device ?
                                            Cheers floor
telecom
Hi floor,
not sure I understood correctly how the machine will work...
Is it you turn one magnet against another which makes them to repel at certain distance, where the work of turning is less than the work produced by the repelling?
The pulley doesn't have to be cylindrical, but rather in the shape of a cam to reflect the changing torque or the repelling force.
Floor
@telecom
Yes you understand correctly.  Except,  I originally thought that it would take less force to close the gap between the magnets by
rotating than by sliding. The measurements say that it is the other way around.  It takes less force to close the gap by sliding than by
rotating. A lot less.
Using a cam could even out the forces, but it would be a really unusually shaped cam, and very steep. I think some other method would
be needed.
At this time I am preparing to republish all of the information in a simple and clear way.
I am hoping that others will duplicate the tests, but so far no one has offered to do so.
                                                   thanks for your time and the ideas.
                                                Cheers floor
telecom
I wonder if LE magnet can be replaced by a solenoid?  This will greatly simplify the operation, as long as it stays within your equation.
Floor
@telecom
Thank you for the suggestion / ideas.
I am building a second test device. This might take some time. The new device will be able to test solenoids, and permanent  magnets of various shapes and designs.
Do you build prototypes?
                                 Cheers
                                         floor
