Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
forest
So a well with a 5 meters of iron pipe underground system is a good electrical ground ? how good is it ? That's the problem. In case of Kapanadze green box video ground had to be able to sink 23Amps.
x_name41
totoalas
Quote from: x_name41 on October 07, 2013, 03:13:02 AM
http://www.youtube.com/watch?v=L8JMkWxoj1A&feature=player_embedded
Carlos schematic!
Using above schematic
220 v    ac   0.4 amps   input    loop current   120 amps    load    60 w lamp       w/o load is 68 amps
the loop cable is a 5 mm stranded wire     its too hot after 2 minutes you cannot touch it
I think that s why they used big size cable for the ampacity rise
In the video he used solid copper wire used in earthing  for the loop
two transformer is enough   the other transformer must have no modification  like for example  1 kw   transformer if you used it for air conditioner      my next test?????
John.K1
Did anybody tried  with one transformer as on the picture from their patent application?  They use 2-3 windings of closed and polarized (+) loop   with the grounding wire hanging on it (not electrically connected). Also I do not think they use complete transformer . In one of their video there is possible to see that one of the coils is missing?
totoalas
Barbosa leal replication  081013  yt  totoalas      using carlos schematic
