Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
vrand
Quote from: totoalas on October 08, 2013, 02:09:38 AM
Barbosa leal replication  081013  yt  totoalas      using carlos schematic
You mentioned earlier of using 6 mm stranded wire for the loop, did you find that the power output was higher with the larger wire?
What was your input to output power level results?
Thanks for sharing your experiment results on this very interesting design.
Cheers
Dave45
Is the energy coming from the ground or the long transmission line, if you notice their ground line is long as well.
Would a long bifilar connected to ground work  ;)
Are we seeing a common denominator here with all these devices.
totoalas
Quote from: vrand on October 08, 2013, 03:34:09 AM
Cheers
Yes on the loop only .... never measured on the light bub yet   but the loop cable surely will melt with this current just like touching a hot iron
vrand
Quote from: Dave45 on October 08, 2013, 09:03:44 AM
Maybe  :D
Talking about windings on an earth ground  ;)
Here is a youtube on
Stubblefield Earth Cell Battery Demonstration
http://www.youtube.com/watch?v=BmNoLfjIEac
QuoteThis is a demonstration of Nathan Stubblefield's invention, the Earth Cell Battery, patented in 1898 (patent no 600,457). It is a coil that when immersed in the earth's surface taps telluric currents of the earth that can be read with a voltimeter.
Two different wires wound on coil then berried in ground, insulated copper wire and iron wire.
