andrea_bor
nelsonrochaa
Quote from: GeoFusion on July 19, 2014, 08:24:08 PM
Hi there nelsonrochaa :)!
Thnk you for your nice comments, yes I have been doing alot of Experimenting for some years now, Have you seen my videos??
Check them out.
I did many experiments with coils and Tesla coils, Royer circuits , and other types of transformers with pulses.
https://www.youtube.com/channel/UCyZZNOLvFRlSMnloejp3FCw/videos
Btw I have seen that you got a Captor, was very interested to hear about this.
I also did some tests and the results are odd yet surprising.
I did replicate a small captor based on what was provided in this thread, and saw that the Fase (hotwire) works with ground very good and
depending how many grounds you connect to each other like I did, managed to pull 2.0~ amps from ground and voltage around 90V.
I  connected e bulbs of 200 watts ( each 100watts )
I have 127V here on the island.
I managed to put plates in ground, 3 plates  of half a meter wide and half a meter long.
Good output, but the more plates I put the more amps and maintains voltage up. But can't touch the ground haha.
But don't know if the meter can count that what I am using.
I will check your videos out,  Because There must be methods of creating a a Hot wire via e inverter that can pull out amps like how I do with the mains hot wire.
Cheerz :), Hope to share more
Hi Geofusion,
yes I've seen most of your videos, and for this reason I recommended your work as it is very interesting.
I also do experiments more than 15 years :) is the hobby of my life;)
The first time I did tests with BMF was 8 years old, and did not understand how he could take advantage of the BMF of the coil of a relay, I saw that there was a discharge but  did not understand that purpose and was addicting me more and more tests, but in there time  there was no internet as now exists to ask questions :) now everything is more accessible, so there is too much information (bad information).
Regarding the "captor" I understood that you do not have the active DN system, therefore
you have done more than one connection to earth and I'm sure that the effect is quite different.
In my case it is impossible to do this kind of test because I live in a 9 floor of a building;)
  I have to use the grounding of electrical building with active protection DN, and it was this problem that made ​​me understand something more about this system.
I think the circuit is no more than a variant of other circuits that make use of back emf or reactive power in ac.
In your latest videos you use the same principles to achieve the effect of feedback
by the ground. (Nice coil).
I appreciate the fact that you visited my channel because otherwise would not have known your work that I recognize is very interesting.
I'm trying to see if I could put a video today with some basic tests in DC
to demonstrate some important points.
Thank you and good experiences
pavqw
Hi Nelson.
I've found a problem in my circuit! I have chinese supply cord where phase and neutral wires are swapped, so there was connected neutral instead phase.
Now I can achieve 185V AC without load! Thats perfect. Unfortunately output power is very poor. If I connect just one LED, then voltage drops to 33V AC @ 40uA.
So If I am correct, I need around 135-757 such devices to get 1W output :)
By the way, this device does not offer free energy. It is not static energy, but simply electromagnetic - same as in transformer but with very poor efficiency. At least it seems to me.
I can measure same amperage in input side as in output.
Probably it could fool a grid meter but thats all :(
It is probably similar principle as Barbosa & Leal device so if it is needed, you can do so rather with direct connection and more amperage with less effort.
nelsonrochaa
Quote from: pavqw on July 20, 2014, 01:09:49 PM
Hi Nelson.
Hi im happy for you :)  This circuit work with static electric . you do not transfer by induction because  if you measure you don't have resistance in primary coil because one leg of the coil is open (fase) .
Think if you simple change the diameter of the brass with more mass . ;)
and more copper. You can improve the output with regulated simple circuit in the output.
good experiences
pavqw
True, well if it works with static energy, it could be a very normal HV capacitor with very small capacitance.
It drains power from input so unfortunately it is not free energy device :( Or am I wrong?
If there is no load, then there is no input and output amperage. It is very clearly visible on my meter.
