forest
there is nothing magical about this methods
explained many times by Tesla
by Tom Bearden
by Tito here on forums
you take a capacitor charge and discharge that's all
look at Bearden degenerative semiconductor circuit picture, replace it with low esr electrolytic capacitor and that's your device
however the engeneering job, experience in building , adjusting, fixing, controlling output voltage, current, protecting from overload , from overcurrent ,from overvoltage,from broken parts (it can explode capacitors for example) is precious ! I really don't understand Georgia people. Give Tariel comfortable life and future for his family and him teach you and will be fine. You have so incredible talented person there and what you did !? that's the greedy world
Hoppy
Quote from: cheappower2012 on December 21, 2014, 06:11:51 AM
To Hoppy
If I got into how exactly I believe Tariels device works
it would be too much,far too crazy.I have a crude model of the operation of the device on how the overunity effect
is created,which I'm refining,it does work,it explains other devices Tariel has made,its going
to be used as a guide in replicating a simple version.Keep in mind its not a free energy device,
but an energy converter,a solar panel is an energy converter,it converts light energy into
electrical energy,the difference in this device is
the energy source is unknown, the energy density is much greater,how the conversion to electrical
energy is done is very different.
Cheappower, thanks for your added comments.
I will hazard a wild guess based on what a.king21 told us about TK's device operating at very a high frequency and high voltage, that it may be possible that he discovered a way to illuminate the lamps using a plasma effect created by high voltage and high frequency, making the lamps look bright at a relatively low energy level derived from batteries and an inverter. This being much the same as compact flouro lamps give high light output at low power consumption. I suggest this is only applicable to the box devices because I firmly believe that the Aqua2 device was faked because TK had to build with conditions set by a.king21 and could not have powered a 2KW fire with the method I'm guessing he used for his box devices. This would render the box devices as virtually useless for commercial production. Anyway, whatever method he used, probably did not rely on energy derived directly from the grid, for the valid reasoning you gave in an earlier post, so a battery operated device would be more likely, albeit offer no real interest commercially. More information on the type of lamps used would be of help here. I have found that halogen lamps can be driven effectively at HV / HF.
What I think we can be reasonably sure of, is that as you suggest, an energy conversion applies here and that the source energy level is considerable and very likely not free.
Zeitmaschine
If we want to measure the amperes of pulsed DC (e.g. output of a diode bridge) then should the clamp meter be set to AC or to DC? Hmmm ...
free power 777
Hello everyone.
Concerning this video: https://www.youtube.com/watch?v=5qsnEchKlc8&index=13&list=PL86OtVC_1KJHeRn0zvSfnNrtOOh02zOYD
look closely at the connections on the output of the PWM and what is  passing in the ampmeter ...  ::)
Sorry for the translation !
best regards.
a.king21
Hoppy:  I once teased Tariel that his device used high voltage and high frequency. His reply was that he agreed with me regarding the high frequency but NOT the high voltage.
Upon investigating his devices I think he was telling the truth. I am becoming more and more convinced that any sparks was and is eye candy designed to throw us off. If he had used high voltage in the aquarium2 my team would have surely sensed it in the earth braid, which was uninsulated. High voltage  also may have interfered with their mobile phones. There was no interference at all.
When the earth lead was disconnected there were no sparks either. The highest voltage the device goes to is in over voltage protection and that is probably in the 1 kv range.  In my experiments with spike back emf I noticed that the higher the frequency, the lower the voltage.
In the 2004 video, the spark gap could have been produced with something like European mains voltages ie no higher than say 350 volts at peak.
