Grumage
[quote author=Pirate88179 link=topic=13721.msg447483#msg447483 date=1429847560
Bill
***EDIT***  I wanted to add that more than likely some, or a lot of this energy may be galvanic but, from the numbers, I don't see how all of it can be.
[/quote]
Dear Bill.
With respect.
I myself feel that this cannot be galvanic, at least what I am seeing. A galvanic reaction requires dissimilar materials. I am using a pair of Copper plated rods !!  The other point I would like to make is the fact that I am seeing the voltage instantly, surety the Ionic path would take some time to cover the 8 M, 26 feet of distance !!
And would galvanism explain this ?   https://www.youtube.com/watch?v=x__NQOtrzf0
Cheers Grum.
Quote from: CANGAS on April 24, 2015, 07:33:36 AM
Well, Tink, you seem to have a common problem with the other professional naysayers around here: you don't waste your valuable time to actually read the news. To your obvious total lack of knowing, commonly said, in your ignorance, his lawn mowing is no problem. Clarence ground rods and their wiring are all under the surface of the ground, after installation, according to rules of the land-owner, as plainly written early in this Thread, as any fool could have clearly seen. If literate.  :) And if having the common human courtesy of actually reading the Thread before blustering into it like a drunk African bull elephant.
CANGAS 165
Well, leaving aside the usual script you are following where people who have no evidence for their claims just insult their questioners rather than providing the evidence.... you've answered the question: He has no need to mow because he must have no lawn left! 60 ground rods "pushed not POUNDED" into the ground with tops below the surface, holes drilled by water-drilling, all connected with buried wires linking them to each other and to his "captor" system..... Let's see a photograph of this great muddy mess.
You're hilarious, with your insults and personal attacks.  Here's the response you deserve for your eighth-grade insults: "I'm rubber you're glue, bounces off me and sticks to you, nyah nyah nyah..."
If you are having trouble decoding that, it means that your silly insults affect the facts not at all, affect me not at all, and only reflect badly upon your own character.
Enjoykin
Quote from: Grumage on April 24, 2015, 01:40:28 PM
Cheers Grum.
Excellent experiment of your son Grum.
What made voltage rising was Scalar electromagnetic filed. H* = - div A.
In two simple words - longitudinal scalar waves running through the rod and ground.
What scalar waves are ?? Kind of preassure waves which make deformation (gradient) of electric potential lines at ground and rod. Remember original Tesla picture from 1900th with air pump pumping earth balloon.
Reg.
Enjoykin !!
ramset
Grum
dragon has some additional thoughts on this "energy from the ground"
he mentioned this patent which highlights a "Jump " phenomena attached to Ferro resonance
http://www.google.com/patents/US3246219
So I asked him the following question
"Have you done any definitive testing on this Jump phenomena ??
or incorporated this into an "energy from the ground"array ?"
His response below
dragon
quote
Yes I have, bluntly speaking, I have no intention of sharing that data or my work in this area at this point in time. I laid out the information for others to investigate its potential, nothing more. In relation to the B&L device think of it as a modulator - instead of a magnet your using current (electromagnet) to alter inductance. That loop to ground , assuming its around 30pf, represents approx Xc= 88 meg ohm at 60 hz. At resonance it is zero. If it passes through resonance, as an example, 120 times per second (full cycle) there is a hard pulse sent into the ground allowing current to return through the same link causing huge shifts.
What would happen if there was an exchange of electrons through the ground loop from the current loop in clarences schematic? A shorted inverter...
The way I interpret this device's function is to send the Line voltage into the current loop then the same line on exit is "mixed" with voltage and its amplified current. So my question would be how do you phase mix the high current in the loop with the voltage/current input from the inverter. Leaving only the ground loop as the solution to phasing.
end quote
Thanks Grandma
GeoFusion
Hi Guyz :)
A reminder on one of the experiments I did with the ground with HV.
Ground Dependent HV HF device
VID 1
https://www.youtube.com/watch?v=M1SP9nMVWec
VID 2
https://www.youtube.com/watch?v=n3hU5CCBt5k
Now imagine 150VDC + input and below 0.5 amps, that would be a a sick output.
The cap and ground is something very important here.
Enjoy.
