1500% energy out!
Started by ingyenenergiagep, August 27, 2013, 03:01:18 PM
Quote from: MenofFather on August 29, 2013, 09:51:08 AM
No. Basicly.
http://www.vershv.narod.ru/sdarticle.pdf
and as extract from this knowledge
the CSIRO Ultrabattery
http://www.csiro.au/en/Outcomes/Energy/Storing-renewable-energy/Ultra-Battery.aspx
Pulsed -higher than grid frequency-charging gives longer cycle life
faster charging time gains
up to 1500 cycles for this lead battery-capacitor combination
This technology is used for battery reconditioning like here:
http://www.novitec.de/index.php/megapulse/megapulse
Sincerely
              CdL
Beginning with the "1500% energy out" we can read that this has been only the savings from 20Vx3,6A to 20Vx0,23A : for a 24V/ 4 Watt  ??? rated bulb !
Member Penno64 is right !
The basic idea using the heat element + driver concept and the result :
will the HF pulsing which for the light bulb means light on/off in ulta-short periods  also deliver energy savings by same heating effect ?
Important here the "Example 1":
http://worldwide.espacenet.com/publicationDetails/description;jsessionid=50F9058C5B61CBED6410E57A58DF3385.espacenet_levelx_prod_1?CC=US&NR=5130608A&KC=A&FT=D&ND=3&date=19920714&DB=EPODOC&locale=en_EP
How fast is the heat element reaction ?
The second search will be the experiment about "OU-generating" batteries !
Sincerely
              CdL
ingyenenergiagep
The voltage will be higher on resonance frequency, and suck the energy from the environment probably.
The sound crashes out the glass of window on reso freq. The trumpet is very loud, but we don't make a lot of work.
http://www.ile.osaka-u.ac.jp/research/THP/pdf/nphoton144.pdf
in modern art used as heating foil :
http://www.m-therm.com/
http://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=1&ND=3&adjacent=true&locale=en_EP&FT=D&date=20031225&CC=EA&NR=004126B1&KC=B1
based by:
non-profit/non commercial invention from 1982 and developed in
East-G.D.R-Germany headed by the (later) Institute-leader Dr.Helmut Reichelt :
this material http://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=14&ND=3&adjacent=true&locale=en_EP&FT=D&date=19910228&CC=DD&NR=287597A5&KC=A5  instead heater function :
cooling with 97% radiation-to-electricity-conversion efficiency proclaimed and integrated a THz-ion(vulgo "electrons")gas-cycle
Sincerely
              CdL
