1500% energy out!
Started by ingyenenergiagep, August 27, 2013, 03:01:18 PM
penno64
Something don't add up
24v x 3.6a = 86.4w
or
p=I x V
or I= P/V
4w / 20v = 0.2 a
Yep, that adds up now.
Penno
MenofFather
"but there may be darker periods in between. 700hz? "
No, here is to hight frenquency to 80 W 24 volts bulb, to meke dark periods.
tinman
If the bulb normaly runs on 50 or 60 htZ,then there would be no dark periods at 700 htZ.
The power consumption difference seems very high between mains power and the wizbang circuit.
Maybe worth a build this one.
ingyenenergiagep
I want use free energy and 230V 1000W line bulbs for heating my room.(Close to 50ohm.)
Heat and light, 2 in 1. :-)
I will try connect a bulb paralell with a coil, without diode.
Drive current: coil and bulb, inductive current: bulb.
The Tesla Switch  operates around 700Hz.  1kWh batt gives 4-5kWh energy(1 guy wrote on Hungarian free energy forum).
DC load, 12V 1A on batt->300 battery cycle.
Impulse load, 1A on batt (100Hz-40kHz): smaller sulfate crystals, less sulfation, more battery cyle, longer battery life?
ingyenenergiagep
