Keppe is headed to the big show, First exotic product to market
Started by ramset, September 10, 2013, 08:40:14 AM
ramset
Thanks Grandma
Paul-R
Can someone describe how it works without using wonk talk like "disinverted metaphysics"?
ramset
TinMan says its a pulse motor,I suppose we will need a bit more info on that ceiling fan he shows running on two watts[??} at the 10 minute mark [approx] Keppe claims it takes 100 watts from the Mains to do the same work with a conventional ceiling Fan?
Goes on to say he can run 10 ceiling fans off one 20 watt solar panel for as long as the sunshines !
That will get My attention!!
The Fan specs [BLADE SPEC AND RPM}will be sought for a load test and I am quite certain some hard data will be forth coming.........
Thx
Chet
Thanks Grandma
tinman
Quote from: Paul-R on September 10, 2013, 10:40:04 AM
Simple terms
You put power in,and fan turns=electric motor.
A little more detail.
Haveing now seen the motor configuration (on pesn),it is a cross between a newman and bendini motor-nothing more.They then return the inductive kickback into the P/in-something we have been doing on my forum for year's.
The title for this thread is not quite right,as this in no way is an exotic product.
What it is,is an over rated pulse motor,designed to decieve the public as to its efficiency.
The wheels have begun to turn,and it will become clear soon enough ,as to what they realy have.
Paul-R
Quote from: tinman on September 10, 2013, 10:57:10 AM
Thanks for the explanation. If their patent overlaps the Bedini, JB will be on their case soon enough.
How is it that these people cannot put the unit on a bench and run it into a prony brake, tell us what the power in is and what the power out is?
